V8 1973 VW Beetle Project - Help Needed! - Page 20 - Hot Rod Forum : Hotrodders Bulletin Board
  #286 (permalink)
Old 10-20-2008, 12:51 PM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Originally Posted by 31chevy
You should be using a cheeze grader or body file. it will work fast to remove body. Looks like you not applying the body with the better method. should have done an additional sweap along the arc of the fender to smooth it better. Lots of people tend to slap the bondo all on in one shot but there just going to end up sand it back off where as they could have created less work by apllying it the right way
You're right. I don't have one at the moment, but will be getting one. I did shave it down some with the putty knife.
I did spread it both ways, but just ended going the direction you see. That works well until I got to the top of the arc. Most of the bondo will stay. I started block sanding until it feathered out. It needs a little more in the center.
This is my first time really doing anything like this. So feel free to help me out.
  #287 (permalink)
Old 10-20-2008, 04:07 PM
Sorry I do not have any pictures of his finished bug, but here are some before it was painted. I hope they load. Because I can't say I know how to do it. IF anyone knows how to post pictures please let me know. Who know I may get lucky and post them.
ID:	33407   Click image for larger version
ID:	33408   Click image for larger version
  #288 (permalink)
Old 10-22-2008, 09:09 AM
Thanks for sharing. I sent and email and got the location of the bug so I'll go check it out one of these days.
  #289 (permalink)
Old 10-27-2008, 08:52 AM
Quick update...
I worked on the rear fenders some more this weekend. I sanded down the first layer of bondo, tapped in some of the high spots and filled in some of the visible low spots. So far it seems like they'll come out decent. The shape is pretty much there, but there's a little filling and tapping here and there that needs to be done. And more sanding of coarse. Another weekend or two and I should be finished with them. This time I used a file to knock down and shaped the bondo as suggested.
These first three pictures are after sanding down the first layer.
Here's where I'm at after sanding down the second coat of bondo. Still a lot more work to do but it's getting there.
  #290 (permalink)
Old 11-03-2008, 08:28 AM
This weekend I had enough time to finish the passenger side fender. Now I need to remove it and smoothen out the mounting edge. The removal should be fun.
A couple quick shots in low light before I left for work.
  #291 (permalink)
Old 11-07-2008, 06:04 AM
SECTION25's Avatar
I'm a closet human
Last journal entry: Flexplate
Mate that rear fender looks really great.
I really like your build, I can't believe how much progress you're making on it, all by yourself.
I think I will be asking for your advice the more my build moves along. It's not a bug though 1963 Pontiac Parisienne. Just simply fixing the bodywork and so on...
Sorry don't wanna hijack your thread. Keep the pictures flowing!
  #292 (permalink)
Old 11-07-2008, 07:16 AM
Thanks! If you have any questions feel free to ask. I'm no expert but I can share what I do know or how I would approach doing the body work.
  #293 (permalink)
Old 11-11-2008, 08:20 AM
That car is gonna be fun, its looking great and I am sure it will turn some heads
I have not been on the forums here in a while but when I saw your work on the fenders (and the whole car for that matter) it reminded me of my bug
here is a quick post about what I have been doing to it
http://www.ls1tech.com/forums/forced...bug-build.html
If you got any questions or need some help or whatever drop me a pm
Keep up the good work! get that thing on the streets!!!!!
  #294 (permalink)
Old 11-11-2008, 08:44 AM
Hey Blob,
Glad to see you've made it back to this forum. Thanks for the compliments. I must say your bug was an inspiration to me as I started my build. I've seen your build up pics, and it going through some of the changes it has, from the 283 to the LS1, but I didn't know you've added a turbo too! Awesome!
I'm still working away on my build. It won't be until late next year when I have mine on the road, I hope, if not sooner. It's getting there though. Body work is taking some time. It'll be fun once it's finished though!
BTW, drop by www.v8bugs.com, you'll find quite many people building V8 bugs. A few of which are using the same chassis design yours is based on, prostreet (glass station build). If you get a chance post a little something about your build. I've posted some pictures of your but I'm sure it's that much cooler hearing from the builder.
  #295 (permalink)
Old 11-12-2008, 10:25 AM
Quick little update.
The fenders released quite easily. I went back and sanded down / smoothed out the seam edge, not pictured.
I did manage to work on the driver's side fender, but didn't quite "finish" shaping it. It needs a little more filler to smooth it out. I'll post pictures once I've finished shaping it.
I'm still sitting on the fence about whether or not to shave the bumpers on my beetle. I prefer the deleted bumper look, but I'm worried somebody might bump me one day just tear up the body of my car. Hmmm... This is really the last thing I need to sort out body work wise.
  #296 (permalink)
Old 11-17-2008, 11:13 AM
Some more body work...
I pretty much have the driver's side rear fender done. Now I just need to remove it and smoothen the edges, but the hard work is over.
Just a little more work and I'll be ready for some high build primer. I'll have to have me a sanding get together and invite my buddy's over to sand down the body to get rid of the 40 grit marks.
  #297 (permalink)
Old 11-17-2008, 02:46 PM
mercmad63's Avatar
Last journal entry: An update
The Fender shape you have achieved there is really on the button as regards the beetles 1930's styling. Well done!
  #298 (permalink)
Old 11-17-2008, 02:51 PM
Thank you! I wasn't too sue how they would turn out but I think they came out pretty decent for a first try.
  #299 (permalink)
Old 12-01-2008, 09:36 AM
Shaved the bumper holes this weekend, but still more to do. So, yeah, decided to go bumperless.
Tack welded in filler strips. So much easier with a mig.
Then I ground the tacks down flush.
Filled with bondo and block sanded with 40 grit until flush.
I didn't get a chance to finish the rear passenger fender cause my bro showed up ready to drink some beer and play the wii. Sometimes free time is hard to find...but was fun nonetheless. Still have to finish that one fender and remove a couple of them so I can block sand the seam edge flush.
  #300 (permalink)
Old 12-05-2008, 06:53 PM
SECTION25's Avatar
I'm a closet human
Car looking good mate
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
1985 LTD 302 V8 Cheap begginer project car 1stPROJECTcar Engine 5 05-27-2011 03:18 PM
corsica v8 project distantfrommost Hotrodding Basics 23 01-16-2010 06:58 AM
New Site Feature: Project Journals Jon Hotrodders' Lounge 8 01-08-2005 10:10 AM
Advise needed for side rail project ye12 Body - Exterior 2 06-15-2004 05:24 PM
