Wow!
Im in Love! Id like to see a few more closer up pics with the blower. HG |
VW Bondo....
HI,instead of all the bondo,why not go to JC Whitney.com,and buy new VW fenders,they will cost less than the Bondo + work...
great looking!
i've got mine on standby for sale
Latest vision of the bug. I was thinking silver or blue, but went back to my original concept but with some C4 black vette wheels because I see so many blue metallic supers it's not even funny.
![]() Also, last night my Mom ordered me some car parts for Christmas. Isky cam #201278 Some Z28 type valve springs to upgrade my vortec heads - #205-D Shim head gaskets - .015 Tranny and frame pad mounts. I'm going by F-Bird'88's recommended build. I actually just ran across this video of how the build will sound. I'm sold on this build. Here's the video. ![]() Has a nastly little idle.
yeah, selling them to a buddy whos going to do them right by restoring them a
yeah works out pretty good.. gettin 2K for my 3 bugs [only ones really good.. and the other two are donors] and a 72 bus...
i get 15%
I had a good amount of time this weekend to get some things done. So much so I'm starting to run out of things to do body work wise...
I finished shaving the fenders that needed finishing. ![]() ![]() ![]() I also shaved the hood handle. I just cut off the button latch. ![]() Prepared the weld area. ![]() Bolted the handle assembly on with a little 1" square piece of 22 gauge sheet metal to fill the button hole. ![]() Welded in the handle, welded the handle to the filler piece, and that piece to the hood. ![]() I then used a cutoff wheel to cut the handle down flush. I the weld the bolts and filler metal to the outer metal of the hood. ![]() Then I ground it flush. ![]() A little body filler and block sanding. ![]() And voilą...Finished! ![]() Next, i want to delete the crescent moon vents and that should be about it body work wise. The onto building a roll bar. |
=D i wanna take it out today..but i dont think i can talk my dad into it i'll just have to DIM[yself] |
Hey guys, update time...
Got some needed parts for Christmas. Motor mounts, tranny mount, shim head gaskets (.015), torque wrench, isky cam #201278, some Lunati valve springs, and Comp Cams double roller chain setup. I'm just lacking a flex plate and harmonic balancer to complete my motor. Did some body work. I shaved the vents on both sides, but kept the indention behind the vents, which I like. I drew out a template ![]() Cut the crescent moon shapes and test fitted. ![]() Then cut the shape out of some 22 gauge sheet metal ![]() Cleaned up the weld area with a 40 grit disk. ![]() Tack welded it in place. I would've welded it up some more but there was a bit of rubber that sealed the vent in there... It caught fire a couple times, slightly. So I did enough tacks to get the job done.![]() Ground down the welds flush. ![]() A little body filler. ![]() Some block sanding, little filler, block sanding....etc. ![]() Hit it with some primer. There's still some little pits so I'll have to go back and work with it some, but it's pretty much there. ![]() Same for the other side. Still a little work to do.
| 1985 LTD 302 V8 Cheap begginer project car | 1stPROJECTcar | Engine | 5 | 05-27-2011 03:18 PM |
| corsica v8 project | distantfrommost | Hotrodding Basics | 23 | 01-16-2010 06:58 AM |
| New Site Feature: Project Journals | Jon | Hotrodders' Lounge | 8 | 01-08-2005 10:10 AM |
| Advise needed for side rail project | ye12 | Body - Exterior | 2 | 06-15-2004 05:24 PM |
