Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 1973 VW Beetle Project - Help Needed!
  #708 (permalink)
Old 10-02-2010, 03:33 PM
V8 Super Beetle's Avatar
V8 Super Beetle V8 Super Beetle is offline
VW makes it, Chevy shakes it..
ere are the results of my paint session. I did one coat of epoxy primer to seal everything and to give a uniform color to paint over. I then sprayed 2 coats of single stag hugger orange and two coats of high solids clear.
I'm pretty happy with the way everything came out, but I did get a little orange peel in some areas, some trash, some solvent pop going on, and a couple of mess ups.
I laid the paint on a little too thick and have some sags and solvent pop going on as mentioned. I do and have planed to sand the panels with 400-600 grit to take care of any orange peel and then spray a wet / over reduced coat so it'll be pretty glassy. Sanding the paint will remove the imperfections.
All in all, it came out decent.
You can see a little bit of the solvent pop. I laid the paint on a little too thick. That's okay, nothing that can't be fixed with a little cutting.
Gotta fix this. : It wasn't the best idea the way I hung the fenders with the plastic and all. No biggie. The fender beading will cover most of it, but I still plan to fix it right with a little rubbing and some touch up spraying.
A little more solvent pop. Tis cool. Will be fixed.
I also did a little video so you could better see the results.
http://www.youtube.com/watch?v=aEPALNDafsI
