Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 1973 VW Beetle Project
  #41 (permalink)
Old 03-02-2008, 09:49 AM
sammyvc sammyvc is offline
help help help
Originally Posted by V8 Super Beetle
I got some frame work done this weekend.
Cut the end of the frame down and I will weld on some new shackle mounts. Possible just might remove the stock mounts from the frame and weld them in the new location or I'll just use some round tubing and what not.
Trimmed down the front.
Here's a pic of the frame shortened at the stock welds. I removed 27.325" between the wheels. I'm in the process of aligning the two pieces back together to be welded. You can see the section from the middle I removed on the floor.
The other side.
The front frame overlaps the rear section.
Here's a shot of the rear. The frame and shackles should fit under the body. We'll see, but looks like it'll work.
Measuring the modified wheelbase.
Looks pretty close. 95.25". I'll have someone help me next weekend just to besure it's the correct wheelbase, to tack it up and then it'll be welded back together.
95.25", Yeee-haawww. j/p.
Next, frame welding then I'll finish removing the body mounts.
please help name is sam.i need your help.can you please tell me the years of s-10's i can use.and the year you uaed.please help
