Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 1973 VW Beetle Project
  #151 (permalink)
Old 06-02-2008, 09:29 AM
V8 Super Beetle's Avatar
V8 Super Beetle V8 Super Beetle is offline
VW makes it, Chevy shakes it..
Finished welding up the fish plate and have the shackle hooked up for the first time. Seems the rear lifted 2 inches. That's OK cause I have some lowering blocks!
I tried to get a shot of how close the shackle is to the fender. It's about an inch away. That's alright cause I have a couple inches to play with as far as moving the body back and I can modify the shackles so they're rounded off instead of square. That should give me the clearance I need.
Once I figure out my welder problem I'll finish up the other shackle and the fender work. Then I'll move on to making a roll bar / cage and finish up the body work so I can start painting / rebuilding the chassis.
It's getting there!
