Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 engine sound, american iron vs. ferrari
  #42 (permalink)
Old 12-20-2012, 02:36 AM
blight blight is offline
Last journal entry: Starting the build, 333ci chev, 195 cc jegs heads
Originally Posted by Augusto View Post
Ford's 351 sounds smoother than SBC's
you would have to have pretty good ears to be able to hear any real difference in "smoothness" if both engines were uses a close as possible setup all around. BUT the firing order is slightly less stressful on the crank shaft in fords. they have a 4-7 swap compared to a chevy firing order.
