V8 mid engine donar cars - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2011, 05:24 PM
Well I want to put a mid engine drive train in my project car and I want to use a V8. What are good donor cars that wont break the bank. My project is a 60s muscle car.
Old 05-26-2011, 05:39 PM
techinspector1's Avatar
Wiki Edits: 326
Take the entire front drive unit out of a '66-'76 Eldorado or Toronado and adapt it to the rear of the frame on your car. That's the inexpensive way. The expensive way is to mount the motor of your choice in the back seat area and twist it through a Porsche transaxle.
http://www.renegadehybrids.com/
A fellow named Bill Porterfield used to be famous for transplanting the GM transaxle into other recipients. Google him and maybe find some other advice.
http://gmc.mybirdfeeder.net/GMCforum...&t=msg&th=7642
Also google Bill's company, Mid Engineering.
Check out these articles on mid/rear engine stuff for 20 cents a page, pretty good deal I'd say....
http://www.v8vairs.com/techarticles.htm
Old 05-27-2011, 04:49 AM
willowbilly3's Avatar
Last journal entry: Body mods
You could also use the next generation of Eldo/Toro/Riveria. Most of them used an Olds based engine. With some work to the oiling system and valvetrain, an Olds small block can handle some respectable hp. One of the problems with any of these, including the 66-76 is the gearing. There aren't many options IIRC.
Old 05-27-2011, 05:42 AM
Actually, the GMC motorhome community has developed different gearsets for these transaxles. They aren't cheap.
Also consider Northstar transverse donors.
Old 05-27-2011, 07:03 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
If you want to stuff a V8 into the back seat of a 60's muscle car, you are really talking rear engine, not mid engine. Unless you want to do extensive body/chassis mods to extend the body, there just isn't enough room from the centeline of the rear wheel wells to the front seat to fit an enigine and transaxle. I did see a concept mid/rear engine '60s mustang fastback, but I never found out how there were going to do the drivetrain. The problem w/ the olds trnasaxle is it put the engine over the rear axle which is good for saving space, not so good for weight distribution if you want to turn. Keep us posted.
Old 05-27-2011, 08:39 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
The C5 and C6 corvettes used a common T56 transmission with a tailsection that was a transaxle. You can put a normal bellhousing on it and mount an engine mid-chassis, but you would be sharing the driver's seat with headers and a valve cover. Not good.
Transverse mounting will probably be your friend, but any of the transverse mounted V8s like have been mentioned will make it a rear engine, not mid. As has been mentioned, steering won't happen
So, here is a crazy idea... What about taking a FWD drivetrain like mentioned above, welding up the differential in the tranny, mount it longitudinally in the back seat with a short driveshaft back to an independent rear? That will solve the length issue. Instead of the whole length of an engine and a tranny, the tranny is kinda tucked under/beside the engine.
Old 05-27-2011, 09:11 AM
The advantage of the Toronado drivetrain is that is is compact, but yes, the engine is balanced over the axles. For a true mid-engine design, what some folks have done is turn the Toro drivetrain around so the engine faces backwards then build a short extension between the trans output face and the differential housing (they come apart). You'll need to flip the differential since it's now turning the other way, but that's easy to do while you're making this spacer. Now you can locate the engine anywhere you want.
The C5 transaxle is also a great idea and you can get it as a T56 as well as a 4L60E.
Old 05-27-2011, 11:30 AM
Mid engine
Wow these are great Ideas. Thank you. Just some thoughts after reading these posts. I like the Idea of using the Toronado and splitting the tans out face and the differential. What years of Toronado are we talking. It sounds like there are several possibilities out there. What about using a latter model Lincoln continental like the early 2000s. Aren't these powerful V8s that are transverse mounted. What problems arise from switching the drive train around.
Old 05-27-2011, 12:09 PM
572hemi's Avatar
im thinking you could probably use the motor of a 90s to 2000 camaro too
Old 05-27-2011, 12:13 PM
Last journal entry: Long time no journal entry, pulled hood tonight.
There once was a good page linked somewhere in the knowledgebase(I think that is where it was) about putting an Eldorado drivetrain in the back of a VW beetle. The guy said it was brutally fast in a straight line, but handling wasn't all that special.
Old 05-27-2011, 12:43 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would do some looking at late model transverse mounted engine packages.. some of those come out on a sub-frame which would make the installation a lot easier. Of course you would need to deal with the ecu and shifter linkage but all in all this may be a good option. Some of those packages do mount the engine fwd of the axle placing the engine in the right spot for a mid engine setup..
Sam
Old 05-27-2011, 01:34 PM
I think it WILL fit. I remember seeing many magazine cars with Toronado drive trains in the backseat space. One I remember vividly was a corvair.
And technically it would be a mid engine since the engine is ahead of the trans axle, or axle centerline. A rear engine would have the engine behind the trans axle.
Old 05-27-2011, 02:29 PM
Wiki Edits: 326
Click on the "mybirdfeeder" link that I gave the OP in post #2.
Old 05-27-2011, 03:38 PM
Unfortunately, in the stock configuration, the engine is about 2/3 behind the axles and 1/3 in front. The RH driveshaft passes under the front part of the oil pan.
Old 05-27-2011, 10:01 PM
Arrowhead's Avatar
Wiki Edits: 5
'32 Ford w/ rear engine and a GM RV transmission
ID:	55608   Click image for larger version
ID:	55609   Click image for larger version
ID:	55610   Click image for larger version
Creating mid-engine cars from front/rear factory cars - your take??? toddshotrods Hotrodders' Lounge 24 05-08-2007 07:31 AM
Found a front clip donar garretthes Suspension - Brakes - Steering 3 04-30-2005 11:54 AM
possible donar garretthes Suspension - Brakes - Steering 6 04-07-2005 12:32 PM
80 Z28 donar car for 53 chevy pickup Aces0vr8s Engine 2 06-09-2004 09:17 PM
multi engine race cars............ onebadmerc Hotrodders' Lounge 9 02-04-2003 04:58 PM
