V8 in original 26 T frame? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2013, 09:07 AM
jaw22w's Avatar
I am going to pick up my new (to me) 1926 T coupe this morning. It is complete less engine, hood , and grille shell. It is in very good shape with only one rust through on the left rear corner. My plan is to install a very mild SBC/700r4. My 27 T roadster is a monster. I don’t need another monster, just something to cruise in with decent MPG’s. I know everybody says that the T frame is not strong enough for a V8. I built the frame for the 27 T roadster, but would like to use the original for this one. My question is…. Can the frame be beefed up to be strong enough? Maybe box the frame with ¼” plate. Reinforce existing cross members. Maybe add cross members or a k member. Of course a newer front axle, newer rear end must be used. What do you think? Anybody done this?
Old 03-26-2013, 11:04 AM
Fully boxing it you would have basically 2x3 tubing. From my memory, I believe that is close to what a T frame is, 2x3, I don't believe it isn't a 2x4 as I remember. That is SERIOUSLY pushing it for a V8. And making a new frame from scratch is a piece of cake for that car so why not just make an identical to original frame out of 2x4 tubing? Because boxing it isn't all that easy, ending up with the frame out of square is a very real result, that is a LOT of welds!
Old 03-26-2013, 11:16 AM
You'd be better off building from scratch or buying one from Spirit, Speedway etc. Or, you could get a Model A or 32 ford chassis and box THAT; but, as MartinSR said, you really need to be a decent fabricator and know how to weld on a structural level. You dont want your ride coming apart at the seams with 600 pounds of SBC hanging out front
Old 03-26-2013, 11:53 AM
delawarebill's Avatar
frame
u can use 1/8 or 3/16 to box it in.. BUT make sure u X brace the frame to keep it from twisting out of shape. yes u can use 2x3 tubing as long as u don't put in maga HP. a friend had a total performance frame, i think 2x4 and had 750hp motor with no problems.. even mine will try to lift the front left tire if i get on it and i'm under 350hp..
Old 03-26-2013, 02:25 PM
Wiki Edits: 27
t frame
In the 50's I boxed the Second roadster project T frame, lots and lots of welding, holes to fill, then grinding . use new tubing and weld in nuts for fender and running board brackets. I use a unibit Cone style drill, and leave a hammer in press fit , that chamfers the hole, Remove plating from the nuts , screw in a bolt and square it up, weld, grind flush, and retap the nuts. depending on the rear suspension usually there is not much room for a k or x crosmember. Most T buckets just have a drop down rear trans mount crossmember . You can buy a new model A front crossmber, and made a rect tube rear one, Take all your dimemsions from the original T frame, and save the T chassis and build a T speedster. I buy in bulk and a T frame only takes $ 100 in material.
Old 03-26-2013, 02:41 PM
jaw22w's Avatar
Thanks guys. I am a certified welder. Been welding and fabricating for 45 years. The welding is no problem. I fabricated my 27 T roadster frame from 2x3x3/16 tubing. It has 450 HP. Frame is plenty stout. A 2x3 frame would be pretty simple to fab up, I was just thinking that it might be easier to just strengthen the original, since you would end up with about the same as a 2x3 frame. But yeah, it might be easier to start from scratch.
ID:	72628   Click image for larger version
Old 03-26-2013, 02:49 PM
jaw22w's Avatar
I was delayed from picking up the coupe until tomorrow because of all the snow, so have just been sitting and thinking about the project today. All the body mounting points are what had me thinking about using the original frame. I am going to make this a full fendered car. The first roadster frame was all custom and non fendered so didn't have to be like the original. The idea of saving it and building a speedster is very interesting.
Old 03-26-2013, 03:09 PM
poncho62's Avatar
Wiki Edits: 5
If you just want a nice cruiser, why not go with a 4 cyl or a v6.....Then you wont have to worry so much about the frame.
Old 04-14-2013, 09:08 PM
hello, beautiful roadster! I'm new to this forum.Yes, I have done it. When I bought my 1927 tall T I boxed the original frame w/ 1/4 " plate. It works well enough. I had a stock 302 SBF in it w/ a C4 & an 8 in. It ain't pretty but I didn"t have alot of money. A 4cyl. or a V6 might be a good idea for a full fendered rod. Theres not alot of room without cutting the stock firewall.
"Original" T frame new-T Body - Exterior 11 08-30-2011 07:21 PM
50 chevy pickup. Original frame wanted. But updated RadRods121 Suspension - Brakes - Steering 2 05-27-2011 01:03 PM
34 Ford original frame dimensions jaykayuk Hotrodding Basics 2 09-16-2008 01:15 PM
Tubbing rear with original frame rails? chieftain Suspension - Brakes - Steering 1 04-25-2007 08:02 PM
26'Tudor v-6 using original frame hotrodderchris Suspension - Brakes - Steering 3 06-04-2002 01:08 PM
