v8 s10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2013, 08:58 PM
v8 s10
i have a 85 s10 and im doing some up grades on one of them is changing the headers to headmen long tube 1 pc headers part number 69490. but it consists of changing the motor mounts part number 9694689. does changing the mounts change the the angel or how far back or forward the engine sits in the truck. any advice would help. im using the headmen shortys and the mounts to go with them on the truck now.
Old 05-09-2013, 09:06 AM
In my honest opinion I would never use those full length headers as they are more pain then what there worth. I have two s10's with 350 sbc in both of them and I use the shorty headers. I once had the full length headers in my 86 s10 and hated them from day one. The header on the passenger side is a two piece header flange and first you put one section in and then the other. The exhaust flange warped big time in less then a year and could never get it to seal after that regardless of what gasket I used. You will also will not be able to run your oil filter from the engine block and will have to use a oil relocater kit. Honestly the shorty headers are not that bad and allows more room for things. Yes you loose some power but if your not racing and need every horsepower then the shorty's are decent. Yes also those other motor mounts will allow engine to be moved some too but I just have welded mounts on my 86 s10.
Old 05-09-2013, 10:16 AM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
them shortys are the way to go if your not all out racin. there aint much room in the s10 with a v8.just did one. moved the engine back 3" .had to lower the steerin colom down 2" to get a fit.yep, we used a bfh! good luck with it.
will s10 pickup fit S10 blazer chassis? peab007 Hotrodding Basics 4 02-28-2012 08:45 PM
s10 tow21 Introduce Yourself 1 04-27-2010 05:40 PM
My S10 nasty91s10 Introduce Yourself 1 07-12-2007 12:47 AM
S10 pickup or S10 Blazer frame? raj4851 Hotrodding Basics 10 01-06-2006 09:28 PM
