v8 s10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2013, 11:23 AM
v8 s10
i have 85 s10 was wondering if anyone has used the headmen long tube 1 pc headers pt.69490 with the motor mounts that u r supposed to use with them pt.4689 dose the engine sit any differnt in the truck than it would with the shorty headers and the mounts that comes in the kit. any help would b nice
Old 05-09-2013, 01:35 PM
The engine will sit about the same, but the headers and engine mount need to match to get tube clearance.
Bogie
Old 05-09-2013, 03:29 PM
u have any pics of this set up or know any one who does so i can c what it all looks like
Old 05-09-2013, 05:49 PM
I do not except for one with shorty headers that I could take pictures of but it uses the Mike Knell installation which is different from the Headman as it modifies the sub mount adapter of the 2.5 Iron Duke and sandwiches the V6 rubber mount between the adapter and the block. However the package is so tight you can't get clear shots of the engine mounts. Mike has two comprehensive books on this subject, I highly recommend you buy both regardless of whose install kit or process you go with.
Chevrolet S-10 Truck
V-8 Conversion Manual
JTR Chevrolet S-10 Truck V-8 Conversion
Chevrolet TPI & TBI
V8 Engine Swapping
V8 TPI & TPI Engine Swap, JTR V8 conversion manual
The Headman sub mount uses the Small 90 degree block V6 or V8 rubber mounts which is quite different than Knell's approach. Headman sells complete kits which include the pan which you will need, they are also different for left or right mount dipsticks. Knell's approach uses the factory pan and will accept left or right dipstick locations.
Forget using 4.3 liter V6 radiators they just don't work. The Corvette unit Mike talks about is marginally OK but pricey the same can be said for the specific S10/15 V8 conversion radiators. The 78-83 Malibu unit is easy to fit, does not require cutting the truck's radiator frame as the filler is angled off the side allowing the hood to close. These can be found in brass as well, 3 row brass cools the same as 2 row aluminum. Idleing and slow traffic being the biggest cooling problem as its hard to get enough fan in there to pull air when your not moving or moving little. This will cool the top end as well as all legal speeds once you get going. These are had new for cheap 1979 Chevrolet malibu All Aluminum Radiator 5.7L V8 350 | All Aluminum Radiator | Chevrolet Parts
Another that I found works well is the Summit 381331. This is about the same size as the Malibu radiator but the filler is on top and will interfer with the hood unless you open the top and engine side face of truck's radiator frame to let it drop into the frame.
You should consider the older short water pump and the accessory mounts and pulleys that requires. This opens the space between the water pump and radiator allowing space for a decent shroud for the fan. This overcomes the idle to low speed cooling issues by getting more air thorugh more of the core than a fan alone can.
You will be constantly space challanged under the hood.
Bogie
Old 05-10-2013, 03:16 PM
thanks 4 all the replys i already have the shortys and the mounts to go with that set up. just wanted to c how the engine sat with long tubes and the style of mounts to go with them. but thanks 4 the info
Old 05-10-2013, 03:47 PM
techinspector1's Avatar
Wiki Edits: 326
Sling those fosdick shorties over the fence and install some long-tube, tuned fenderwell headers. Whatever's in the way, cut out of the way with a good Sawzall.
Old 05-15-2013, 09:03 PM
lol yea that would work if it was a just a drag truck but im goin to race and drive it so i need a full exhaust.
will s10 pickup fit S10 blazer chassis? peab007 Hotrodding Basics 4 02-28-2012 09:45 PM
S10 v8 wayneo Body - Exterior 1 10-13-2007 09:13 PM
v8 s10 morgo Engine 4 08-20-2006 09:23 PM
S10 pickup or S10 Blazer frame? raj4851 Hotrodding Basics 10 01-06-2006 10:28 PM
S10 LunaticSage Engine 4 08-23-2003 01:32 PM
