We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 02-20-2004, 03:47 PM
Selwyn3III's Avatar
Selwyn3III Selwyn3III is offline
New Member
v8 s10
Found a small block 350. Its out of a 89 chevy truck and the guy wants 100 bucks for it. It is fuel injected. How hard will it be to change it from efi to carb? What will i have to change? Thanks.
Old 02-20-2004, 03:55 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
2nd Gunman On The Grassy Knoll
any basic small block 12 bolt intake will fit, however, the 87 and up heads 4 center intake bolts are at a different angle, so the intake must be drilled for the new angle if it`s a 86 and earlier intake, a machine shop can handle this job with ease, everything else is a basic bolt on.
Old 02-20-2004, 04:11 PM
Selwyn3III's Avatar
New Member
What if i was to put heads on it from an earlier carbureted engine or aftermarket vortec heads. Couldnt i fit the intake on with no problem?
Old 02-20-2004, 04:29 PM
Vortec heads aren`t aftermarket, there factory GM heads, the Vortecs require a vortec intake which has a straight up right 8 bolt pattern, I do not recommed having a older intake drilled for use on vortec heads. as for the older heads, they`ll bolt right on the 1989 block.
Old 02-20-2004, 06:40 PM
Selwyn3III's Avatar
New Member
WELL I WOULD PREFER TO NOT EVEN CHANGE THE HEADS RIGHT NOW BUT I DONT REALLY LIKE THE IDEA OF DRILLING THE INTAKE TO MAKE IT FIT. ANY INTAKES THAT WOULD BOLT ON WITH NO DRILLING OR MODIFYING?
Old 02-20-2004, 10:43 PM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
edelbrock makes a bolt on intake to fit the tbi heads as well as the vortec heads.
Old 02-21-2004, 09:34 AM
Selwyn3III's Avatar
New Member
OK THATS EXACTLY WHAT I WAS LOOKING FOR. THANKS
Old 02-21-2004, 11:30 AM
roys63's Avatar
roys63 roys63 is offline
And you need to check the Fuel pump mounting most of the fuel-injection blocks are not drilled, you will need a electric pump.
Old 02-21-2004, 02:16 PM
NorthStar NorthStar is offline
If youre on a tight budget GM makes a carebureted intake for TBI heads too. Cruise around the bone yard you might find one.
Old 02-21-2004, 02:30 PM
Selwyn3III's Avatar
New Member
WELL IM GOING TO BE PUTTING THIS ENGINE IN AN S10 SO IM PLANNING ON BUYING ALL NEW FUEL PUMP AND ALL THE OTHER ACCESSORIES. THANKS FOR INFO
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
