v8 S10 build
Hey everyone,
My friend and i are in the middle of a huge project our goal is to swap my 1988 GMC S15 i2.5 liter truck, we have a a980's 305 block that we are building for the rebuild. So far we have the block and have recently purchased heads and an intake. We would like to get this project done as soon as possible but need help and information on how to go about it and what parts would be recomended. We have created a site to try and get people to email us and leave messages or info on this project, we would appreciate any help that anyone can give. To do so visit us at http://www.v8struck.com/ thank you for your help and support it is greatly appreciated |
Jimmy Beam is in town tonight, so I'm sure I'll sound dislexic if I try and tell you what I did to my truck, but I'm sure I've written it down somewhere in this site. Try a search, there were a bunch of threads on the subject, and guys like TurboS-10 have done excellent work on their projects. All I'll tell you is that I had the engine in and running in a weekend, so it's not that huge of a project. Good luck.
OMG am I drunk or are you trying to put a 305 in an S-15? Oh yeah, Jimmy Beam. First piece of advice, dump the 305 in favor of a 350. The 350 has the same outer dimensions with a whole HE double hockey sticks of lot more power and available parts to make more power. Please, from one converter to another, reconsider the 305. The other guys who went to the bother of converting and shoehorned a 350 instead of a 305, will laugh at you from the other end of the strip if you don't. Last edited by flyfisher; 09-29-2004 at 05:22 PM. |
you should be able to find every thing you need to know in this forum. http://www.v8s10.org/forum/index.php
s15 bulid
Everyone thank you for your help so far,
we are using hugger headers that we purchased and have heard that you dont need to use a mini starter but a regular one will work is this true? Also the radiator we are planning on using is the one that JTR sells it is the corvette radiator. I also wanted to know what rear end to use i have heard of several but no one has told what vehicle to get one from. Also looking for any transmission info you could give to me. Thank you and i will keep you posted. |
Sounds like you coming along. What tranny are you using automatic would be easier.I used a turbo350 and all I had to do was redrill the trans mount holes and you want the one with the long taol shaft. for the rear keep the stock one until the old one breaks I dog the **** out of mine and the rear was fine.Also if you use the turbo 3590 with the long tail shaft you can use the stock drive shaft
305 build
So far we are planning on using the TH350 transmission because we have heard that the auto is easier and the best way to go. I have heard that the rear end snaps easy though is it true that it wont? Also what should i use for the radiator i have heard of the one offered by JTR but that is rather expesive is there an alternate way to go? For now that is pretty much where we are held up trying to find a good transmission for decent money. Thank you for your help again any info is apreciated.
No its not true the "Rear end will snap" My s-10 has had its current rear (stock) for over 2 years, and I have had no problems. Keep in mind, the S-10 will have very little traction with-out tubbing the rear for bigger tires, so you will have no problems with the rear end.
As for Radiators, I bought a aluminum 4 core from AFCO for mine, for around $225 CDN so they are pretty cheap. Just take your measurments of what you need, and order it up. bonuts |
The stock rear will be fine with street tires. If you plan on running slicks it will eventually break. BTW I've seen S10's with 9" wide tires cut 1.5xx 60' times so tubbing is not necessary, just have to get the chassis right.
I'm using the stock rear in mine with no problems. I also opted for the 350 automatic, but I do plan on going with an OD trans in the future. V-8 S-10's are a BLAST to drive!
Good Luck! Oops! I'm also using a 4.3 V-6 Rad from a S-10 Blazer, again, no problems. |
S15 build
Yeah i think i will stick with the stock rear untill i can afford a posi. That would be awesome. And that is great that the 4.3 radiator will work, i will be able to get one of those pretty easy. But what about a tranny cooler do i just mount a remote one? And your right V8 s10s are awesome. People tell me jsut to get a camaro or a sports car but those are common V8 s10s are truely a bread of their own. Thanks everyone and keep the info coming it is proving very useful.
Thanks again. |
I used an external tranny cooler.
The one that S10Fan has really looks good. It looks like everything was designed for it. He apparently has a knack for finding the stuff that works. If he could just get rid of that annoying whine from the gear drive. LOL
That "whine" brings back memories of the ex-wife, however, this time I can stop the "whine" whenever I want! |
| Recent General Rodding Tech posts with photos |
