v8 s10 converstion,700r4 or turbo 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2007, 10:48 AM
which is better, my friend thinks to go with the 700r4, but im thinking about the O/D hook up issuses,we think the 700r4 has a higher 1st gear!
any imfo would be appreated!
thanks
Old 03-06-2007, 02:20 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
The 700 has a very low first gear at 3.06:1. Then it has the largest gear split of any auto tranny on the road since 2nd is 1.63. GM did it to crutch the fact that they put super-high gearing in some vehicles to get lower highway RPM, so they lowered first to recover some of the torque multiplication.
For that reason, 700s are best suited to broad torque curves in lighter cars. You s10 is light enough. I would say... if you want OD, the 200-4r is a better choice up to 350 lb-ft. The 700 is fine as long as you're not looking for max acceleration. It will be fine in a daily driver.
350 would be OK, but to get a good street performance gearing you'll be spinning pretty fast on the highway and MPG will suffer.
Old 03-06-2007, 02:21 PM
curtis73's Avatar
Wiki Edits: 16
http://www.maliburacing.com/auto_tranny_id.htm
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
700r4 to 350 turbo. 68novafan Transmission - Rearend 14 03-26-2005 06:52 PM
Turbo 350 Trouble in 85 gmc jdimassi Transmission - Rearend 7 01-26-2003 01:34 PM
turbo 350 4doorjoe Transmission - Rearend 1 01-03-2003 03:53 PM
87 s10 v8 conversion too__old_for_this Engine 5 11-23-2002 05:24 PM
