http://www.therangerstation.com/tech...nversions.html I hope this helps.
you MUST use a stang 5.0L the truck motor has a different oil pump and pan, which WILL NOT fit. about the tranny, get a t-5 with a t-case adaptor (it is 4x4 isn't it?) or get a tranny from a fullsize if your willing to do some tunnel mods.
Everybody loves mustangs...
Yeah it's a 4x4. A mustang motor huh? Why not use a motor out of 88' or higher f series truck? I don't know about a mustang motor. This is a local junkyard with cars and trucks no older than 1985. I don't know any place around where I live that would allow a good deal on a stang mill. Like I said, my friend works at the junkyard I mentioned, and he can give me a SWEET deal on a motor/tranny out of a truck. A price like $300 at the max.
i believe the front of your truck is similar to the explorer, if it is, the oil pan will not clear the x member, if it is the earier one, i can't help you, although, i believe they are like the the f-series.
Mine is an 88'
Actually, rangers and bronco II's looked like explorers from 1989 through 1992. Then the ranger took on a different look after 92', and the bronco II was replaced with the explorer in 1991. My Bronco II is an 88' which resembles a ranger from the same years and below. (square headlights) The 302 swap vehicles I saw were 88' or older bronco II's. That brace you mentioned is pretty far away from the sump of my oil pan, so I don't think that will be a problem. But thanks for the tip!
Ranger motor instead?
Well I could also drop in a bigger 4.0L. These would be a little cheaper, and if it was out of a ranger, then it would drop right in without a lot of modifications. Yeah I don't want to change the camber with a heavier engine. So I might just use the 4.0L. It will give me some more power than my 2.9L, plus there are more parts available for 4.0's.
Aslong as he isn't going to prerun or mud that is a good thing in a offroad truck
The upper & lower intake on a 302 are differant for the truck & the stang. The truck intake is "ALOT" taller .About 4" to 5" higher. I do not think it will fit under the hood of a Bronco II. I have seen a Bronco II with a fuel injected engine , but it had a aftermarket intake manifold for a Mustang.
Engine Swaps
There are several afteramarket swap kits available for putting a 302 in a Ranger, and since your Bronco II is the same chassis, these will work quite well. As for the oil pan, I believe they are referring to the double hump pan used on 302's from about 84 or 85 on up in the Mustangs. You dont have to use the block specific as the pan will bolt to any 302. Just be sure to get the dip stick assembly along with it as the regular dipstick which mounts on the timing cover wont work with the double hump pan.
The 4 liter V-6 was offered in Rangers from about 88 on up, so I dont think swapping one of them into your Bronco II should be anymore than a bolt in job as well. IF you elect to go with the 4 liter swap, you might want to consider finding a wrecked ranger with one in it, for a donor vehicle. This will give you all the correct wiring etc, and you wont have to do so much splicing and cussing while wiring the vehicle. When you are done, you can always take the bed, if its any good, and make a trailer out of it, or some such, and junk the rest. |
If I remember correctly we made a lot of changes to the Ranger between the Bronco II era and the Expedition. Check with the experts on the RangerStation site, they have some folks that are very up to speed on interchangability. The swaps mentioned are doable, but the amount of work might be a lot more with one combo than another.
There is alot of info at BRONCOII.ORG. They have the answers to the questions your asking.
| 55 Chevy 3100 v8 swap questions | rarevair65 | Engine | 1 | 02-19-2004 03:04 PM |
| 1991 chevy 4wd V6 swap to V8 | Michael Breaux | Engine | 3 | 10-20-2002 02:48 PM |
| 1963 fairlane v8 swap draglink | FAIRLANE DUDE | Suspension - Brakes - Steering | 3 | 09-24-2002 10:46 AM |
| pontiac V6 to chevy V8 swap | snake | Engine | 2 | 01-20-2002 03:58 PM |
