V8 trike?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2013, 08:19 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
V8 trike??
hey all.
lookin into buildin a v8 trike. Not the ole stubby death trap but one of the longer stretched out ones.
i want a stretched front end so im going to have to use a heavy duty front end but what kind do they use on em? probably use a 12 bolt or 9 inch rear about the width of an s-10.
Anyone know much bout em? Goods...Bads...anything will help. Kinda like one of these. tnx, HG
http://www.gogocycles.com/images/cus...e-21456011.jpg
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 04-21-2013, 08:27 PM
life is a temporary assignment
Originally Posted by HemmiGremmie View Post
hey all.
Very cool.. I always wanted to build one,, Never had a front end fall in my lap.. But will one day.. Don't seem like you would need much as light as it would be.. Alot of tire spin.. So you shouldn't be breaking anything with a light rear end.. But I think I would have to pick the 9''..
Old 04-21-2013, 09:18 PM
31 five window
Last journal entry: grill and rear end
I always wanted to build one but I was going to use a Powerglide with a shorty kit and a Vette rear to keep it short.I have seen some use an Ultraglide front end with no problem.I think a Goldwing would be good also,off of one with the 6 cyl.
Old 04-27-2013, 12:51 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Any trike doesn't corner worth a damm.
Old 04-27-2013, 06:57 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Build a reverse trike..those handle well..
Sam
Old 04-27-2013, 07:16 AM
delawarebill's Avatar
trike
many yrs ago.. i built a trike with a VW drive train.. worked well and used a std springer 21" over front end. just in case u change your mind.. the vw train was turned backward so the engine was in front.. pulling the ring gear from one side and placing in the other side allowed it to move in normal direction. the shifter was the biggest problem but was solved..
all in all the trike drove great, but very light front end weight.
find one of those factory built v8's and ask questions...
Old 04-27-2013, 08:15 AM
Wiki Edits: 27
the geometry ?
A friend has one up on a sign post in front of his shop He didn't get the front end geometry right and said it was too scarry to drive
Old 04-27-2013, 09:13 AM
Banned
if you want a long trike this is the guy to get a front end from .
Sugar Bear Choppers .com
Old 04-27-2013, 03:19 PM
Banned
hey hemi check out this killer hemi trike!
https://www.youtube.com/watch?v=su7gNQf8gK8
Old 04-28-2013, 01:02 AM
Sometimes in hotrodding you have to give up a little to have what you want..
Old 05-01-2013, 08:52 AM
I like this trike. Anyone have any links that have more techincal info on it? I'm interested in more info on how the front wheel/suspension is setup. You have to admit, that engine has the perfect sounding idle!!!
Mid-Engine V6 Vortec Trike VDubs Introduce Yourself 2 11-06-2011 08:12 AM
fiberglass trike box mimoose Body - Exterior 30 10-03-2011 11:29 AM
Man !!! Is this a Trike !!! Are what!!! NEW INTERIORS Hotrodders' Lounge 7 11-02-2009 08:37 PM
Transmission for a v/8 powered trike? Bad Rat Transmission - Rearend 31 02-17-2009 12:57 PM
68 volks trike rally4x4racer Engine 7 03-27-2005 07:46 PM
