V8 w/ carburetor + eletric fuel, runs too rich. Do I need a fuel pressure regulator? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2009, 07:23 AM
5_speed's Avatar
1988 Dodge Dakota 318 Magnum
Got a new project from my brother, 88 dodge pickup (5spd) 4x4 with a 97 5.2L Magnum 318. Edelbrock 1406 (600cfm) carb, and an electric fuel pump that's always on when the key is on.
I failed state carbon monoxide emissions. The standard was about 1.25 or so, and I ran a 4.45.
After some research I understand this typically happens when running too rich.
Do I need a fuel pressure regulator, and if so how do I know its the right one?
Any help appreciated, thanks!
Heres a pic for good measure since I haven't been around for a while since I sold the Camaro:
Old 10-21-2009, 07:45 AM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
You can quickly check to see if your fuel pressure is excessive by either splicing a T fitting into the fuel line and hooking up a pressure gauge or, since your pump runs with the key on - just pull the fuel line off the carb and put in on a gauge. You don't want to go over 5 lbs.
You could be experiencing an ignition timing issue as well, if the spark is not timed correctly it can also increase emissions.
Old 10-21-2009, 07:49 AM
is that test done at idle or at some set rpm?
what is the initial timing set at?
have you made any adjustments to the carb (idle mixture or jets)?
Old 10-21-2009, 08:00 AM
5_speed's Avatar
A rubber fuel line feeds the carb, I can disconnect that and hook a gauge to it I'll go buy one.
The emissions test is donw between 2,000-2,500 rpms. They had mine at 2,300 rpms.
Brother says he set ignition timing at -12 degrees (advanced.)
Only adjustments to carburetor were the idle mixture screws which I messed with to get the highest possible vacuum at idle with out losing more than 40 rpms.. I got 21 in/Hg @ idle.
More features of this truck as as follows: Pertronix stand-alone distributor, and MSD blaster coil. Dunno if that matters?
Old 10-21-2009, 08:19 AM
sqzbox's Avatar
My pipes are my music
An adj. vacuum fuel pressure regulator should do the trick. It will only pump the pressure you need regulated by engine demand.
Old 10-21-2009, 08:40 AM
techinspector1's Avatar
Wiki Edits: 326
Here's the Edelbrock Owner's Manual. Use it to do step by step tuning of your carb and you should fly through emissions testing......
http://www.edelbrock.com/automotive_...ers_manual.pdf
Here are 6 pages of jets....
http://www.summitracing.com/search/P...Edelbrock+jets
And 10 pages of metering rods. Be careful here, they have Quadrajet rods mixed in with Performer rods. There are also Summit brand rods for Performers....
http://www.summitracing.com/search/?...ng+Rods&page=1
And 4 different diameter needle and seat combos....
http://www.summitracing.com/search/?...e%20seat&dds=1
Old 10-21-2009, 08:58 AM
5_speed's Avatar
This is my second time dealing with a carbureted vehicle, so I'll have to do some research before I click the links to figure out how all of the parts work, but I do thank you for the links.
I just bought a fuel pressure gauge, and regulator 1-6 psi. I will go check the fuel pressure, and if it's over 5/6 I'll install the regulator and see how it runs / drives after that.
It is hesitant to accelerate now so maybe this will fix that too.. does flooding/ rich cause hesitation?
Old 10-21-2009, 09:42 AM
5_speed's Avatar
hmm, now I am stumped. I hooked up a fuel pressure gauge and all I was getting was 4.5 psi. just before the carburetor.
That doesn't make sense, because there is absolutely no inline regulator, and unless the fuel filter is that clogged up, I don't understand how they were able to do this.
Well, back to the drawing board I guess, is 4.5 psi ok for street driving?
Must be up to the pieces of the carburetor itself now?.. confused.
Old 10-21-2009, 09:59 AM
Rustydawg's Avatar
Your 4.5 psi is fine, no problem there. There is most likely a bypass regulator built in to the electric pump.
Your issue is not fuel pressure but carburetor and possibly ignition tuning - print off the Edelbrock tuning guide and read up on carburetor function and you'll be ahead.
I'm rather shocked that CO emissions was your only issue for the test - what with the open element air cleaner and modified ignition I would assume that would be a problem right there - apparently not.
Old 10-21-2009, 10:31 AM
5_speed's Avatar
In NJ if you swap an engine it must be by the same manufacturer as the original, and be of the same year, or newer. 88 dodge truck with dodge 97 was ok with them.
The truck has true dual exhaust, 1 cat-conv. per bank of cylinders - they were glad to see that.
Old 10-21-2009, 10:40 AM
BrutalBronco's Avatar
Life's Short, Drive Naked Once
600 cfm AFB
sounds like metering rod changes will help you pass. find out which one it's running and increase the cruise size and keep the power size. for example if you have 65-47, install a 68-47 or 70-47. another consideration would also check float levels of the carb just to make sure they're not too high. (specs should be in the owner's manual.) then, I would dial in the ignition timing.
ps 4.5 psi sounds fine for your setup
Old 10-21-2009, 11:24 AM
Wiki Edits: 326
Another thought about the air cleaner. If there is insufficient filter area for the cubic inches of the motor, there will be a restriction there at the element that could cause additional vacuum and possible enrichment of the air/fuel ratio. I know from going through emissions testing here in Arizona that a high reading will be shown if the air filter element is clogged. It makes sense to me that a filter of insufficient area would do the same thing.
On a 350 for instance, I like to use a 14 x 3 filter (131.88 square inches of filter area). Using this seat-of-the-pants 0.377 square inches of filter area per each cubic inch rule of thumb would indicate that a 318 would like around 120 square inches of filter area.
I think I would be looking around for a larger filter housing that would work on the ebrock carb and allow you to fit more filter area onto the motor. Might work, might not, but I'd be looking at this change along with dialing in the jets/metering rods and float level.
Old 10-25-2009, 06:48 AM
5_speed's Avatar
I took the carburetor out, rebuilt it to learn what every part of it is and tuned it through and through. The truck runs great now, but as I looked at the exhaust having someone rev the engine for me to check the exhaust I realized I'm puffing a bit of smoke, especially from the left side (true dual exhaust.) They hook up to the left side to do the emissions test.
This engine has really been used, towing, racing etc. The valve stem seals are probably due to be replaced.
Could the burning oil have caused me to fail emissions for high carbon monoxide levels?
Old 10-25-2009, 07:35 AM
sqzbox's Avatar
In your second pic, was that the way you took it in for testing? or were you in the process of working on it? Reason I ask is I don't see any vacuum lines to the port's on the front of the carb, connected. Where you run your advance hose to, is your choice, but I would think about setting the initial timing to the spec's on the tag under the hood. This would include, having the vacuum adv. hose hooked up to the proper vacuum port (ported vacuum or manifold vacuum). I don't see a vacuum line going to your ported fitting on the front of the carb or the full maifold vacuum port. Then again, maybe you don't have vacuum adv and it's all electronic.
Old 10-25-2009, 08:06 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Plus what your current air filter , one backfire and she will go up in flames. Those air cleaners have been the death of many a hot rodders ride. Get rid of it like yesterday.
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
Fuel pressure gauge moves to 0 on start 406 bug Engine 27 12-02-2008 04:39 PM
DARK brown--BLACK plugs SBC Joshua Lee Engine 128 02-03-2008 09:12 AM
Camaro V6 to V8.. anyone ever done it? C10 Engine 3 11-23-2007 12:12 PM
Fuel Pressure Variance slomotion Engine 2 04-02-2002 01:25 PM
