Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - vac advance help.
  #50 (permalink)
Old 11-12-2004, 06:00 PM
wildman926's Avatar
wildman926 wildman926 is offline
Never let them see you coming
TMOD,
So it looks like your cannister takes at least 10" of vacuum before it starts to provide advance, which sounds like it would be more for a stock motor/less duration cam than a performance motor/more duration cam. Cool.
I have an HEI with Pertronix upgrade kit, and the cannister takes 4" of vacuum to start advance, and 11" for full advance for a 10 degree total advance, of which it is fully adjustable from 0-20 degrees. It seems to me that depending on the components that are installed (carb size relevant to engine requirements, cannister, duration of camshaft, etc.), as to what the outcome of a particular graph such as above would be.
This hobbie is cool, you can always learn something.
