vac line on 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2010, 09:20 PM
vac line on 700r4
stupid question but does the vaccuum line from the trans hook to the manifold or carb?
Old 06-14-2010, 10:20 PM
700 dont have vac lines
Old 06-15-2010, 01:14 AM
sqzbox's Avatar
My pipes are my music
Perhaps you have a th350C. what year car and engine do you have?
Old 06-15-2010, 07:19 AM
sorry for my ignorance it is a 700r4 but the motor thats being used has a long vac line still connected to the manifold that i am assuming was used on the trans that it was bolted to at one time. I apoligize for not thinking clearly lol, thanks for setting me straight
Old 06-15-2010, 07:20 AM
64 chevy impala and its a 454 engine
Old 06-15-2010, 07:42 AM
sqzbox's Avatar
OK, pull the hose and cap the port on the manifold. Nice combo in a 64. I had one back in 74. 327 and PG tranny. It rode smooth as glass to 120 mph!
Curious though, what kind of shifter was installed for the 700R4?
Old 06-15-2010, 11:37 AM
not really sure it was a friend of the family that built the trans. yea its been sitting in my garage for years untouched but my dad has taken the bull by the horns by working on getting it together
Old 06-19-2010, 12:15 AM
vacume line
I have a 700R4, rebuilt it and put a valve body from TCI that keeps 200 lbs. line pressure .This is suppose to keep one from wasting 3rd and 4th clutches if your TV cable is not adjusted right. Well, about vacuum line.TCI sent a vacuum switch with ground wire running through it, called them and they said to run it from carb. this operates ground wire to trans. plug. I am going to try it ,
Old 06-19-2010, 09:49 AM
sbchevfreak's Avatar
Licenced Automotive Technician
Sounds like the vacuum switch they sent is to control converter clutch lockup.
Old 06-27-2010, 11:46 AM
wdmickjr's Avatar
vacuum switch in the TCI 376600 is the World Magnetics PSF 101. opeartes in NO or NC at 8-10hg.
terrible gas milage help!! hddave1 Engine 124 03-31-2008 11:57 AM
3/8" female to male flex line needed. Any cars front wheel cylinder frame line? Ripped Suspension - Brakes - Steering 2 03-12-2008 03:47 PM
Splicing Vac. Line MrPhotographer06 General Rodding Tech 6 01-05-2008 11:39 PM
Timing advance issues... autonuerotic Engine 27 11-22-2006 07:51 PM
Timed Vac Port or Manifold Vac Port Sweet-34 Electrical 14 04-27-2004 05:35 AM
