vac secondary carb or double pump??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2003, 10:04 PM
maddmaxx's Avatar
In response to a previous post, willys36 and frisco both suggested that I switch to a vacuum secondary carb instead of the double pumper Holley I currently have on my 350. I searched through a couple of parts magazines and all I see as far as vacuum secondary carbs are single fuel line feeds. Would I not be losing power or performance by switching "down" to a single line instead of a double pumper???
Old 10-31-2003, 10:41 PM
mstngjoe's Avatar
I believe the Holley 3310 is a dual feed vac secondary.
Old 11-01-2003, 07:03 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Ditto, the Holly # 3310 is a vacuum secondary duel feed 750 carb and a very good one. A single line is just as good for all street apps.
Luv the smell of NITRO in the morning.
Old 11-01-2003, 07:07 AM
1BAD80 is right. The 3310 Holley is a very good carb especially for street applications.
Old 11-01-2003, 08:38 AM
302 Z28's Avatar
The 4160 series of the Street Avenger carbs are all dual feed single pumper vac secondaries.
Vince
Old 11-01-2003, 08:40 AM
maddmaxx's Avatar
Talking
Thanks all. I am checking on those suggestions right now.
Old 11-01-2003, 08:48 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
I think you are confused, as are many, on what a double pumper is. It has nothing to do with fuel lines. Double pumpers have a mechanical secondary with an accelerator pump same as the primary side. They can be dual or single fuel line.
Chris
Old 11-01-2003, 08:50 AM
maddmaxx's Avatar
You are right. I just read about that on the Holley website. I just wanted to make sure going down to one fuel inlet wasnt going to cause me to lose performance.
Old 11-01-2003, 10:45 AM
66RETROFALCON's Avatar
New Member
Cool SINGLE VS DUAL
Even if you did buy a single feed fuel line carb it can be easily and fairly inexpensively switched to dual feed just by changing the fuel bowls to the correct dual fuel line setup.
Old 11-01-2003, 01:24 PM
1BAD80's Avatar
Wiki Edits: 2
In my photo album it shows both type of setups, single one on a set of 390 carbs and and the other feeding with two separate 650 Dps on page 2.
A single one feeds to the other bowl OK.
Single and duel can be had on most #4160 carbs.
There are after-market fittings to be put on carb to change gas line inputs, single to duel by changing it to a 4150 style and duel to separate.
Old 11-01-2003, 01:53 PM
willys36@aol.com's Avatar
Wiki Edits: 21
It would take an INCREDIBLE engine to overdraw a single feed carburetor. We're talking several thousand horsepower. That shouldn't give you a second thought when choosing a carb.
