Vaccum cannister line blocked off - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2009, 06:39 AM
In my earnst to have an uncluttered looking engine compartment bereft of the stock vaccum cannister, I plugged up the line from the fuel tank that would go into the cannister.. Not wanting to hi-jack the thread lower down on the page, believe it was AP72 that said he had a load of problems as he was working on a car with the line plugged.. What happens when the line is plugged gennemen, and the cannister is not there anymore??
T.
Old 12-12-2009, 01:19 PM
DoubleVision's Avatar
Friend and I both had identical cutlasses. I blocked off the line and so did he.
Not long after I had nothing but endless fuel pressure problems. His, never developed any. I removed the plug and it was fine, but I didn`t like having to smell fuel vapour everytime I shut the car down. If you can get a vented gas cap then you can block the line without problem, but I think I tried 5 different caps to no avail.
76 Vette vacuum cannister plumbing sandiegopaul Engine 1 04-25-2009 07:29 PM
Could It be my Fuel Tank / Fuel Line? 10mikeymike Engine 4 09-17-2008 02:25 PM
fuel line leak torrey Engine 8 06-29-2008 04:06 PM
vaccum line for th350? fireforsin Engine 3 05-25-2006 06:13 PM
74 olds 455 little line on fuel pump 225buick Engine 2 04-09-2003 08:23 PM
