Vaccum hose above my brake pedal?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2008, 09:47 PM
labreejr's Avatar
I've got a 84 Cutlass I'm rebuilding. I put a Chevy 383 in it and I'm now getting rid of some of the unused wiring. There is a rubber hose connected to some sort of switch on my brake pedal. It runs thru the firewall into the engine bay where it just hangs. What should this go to?
Old 12-28-2008, 07:43 AM
rachet ralph's Avatar
that vacuum hose is for cruise control and if your not using cruise, i'd change brake switch, some cars have 2 switches going to brake pedal, i know cutlass i stripped for parts did have 2 brake switches one for brake lights and other for cruise control and to operate TCC switch in trans, so if no cruise or lock up converter i'd remove the switch and hose.
Old 12-28-2008, 12:58 PM
Just to expand on the previous post a little, the purpose of that vacuum hose and valve is to immediately dump the vacuum in the cruise control actuator so the throttle returns to idle quickly. The assumption is that if you're on the brakes, you don't want the cruise control holding the throttle open. It's also a backup in case the valve in the cruise actuator sticks. If you are keeping the cruise, you need it. If not, you can get rid of it.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Brake Pedal ratio: manual-to-power conversion wfritchen Suspension - Brakes - Steering 2 06-21-2007 06:12 PM
No consistent brake pedal risaacp Suspension - Brakes - Steering 15 10-21-2006 06:46 PM
Check this brake pedal kit out and give me your opinion, please. Jeepster Suspension - Brakes - Steering 2 03-12-2006 07:12 PM
