Will a vaccum reservoir work to sustain a TH400 trans.? I'm not to sure myself wether or not they are built for constant draw, or momentary draw. I am trying to solve a too big-a-cam and auto tranny problem. Thanx.
A vacuum reservoir is designed for a constant vacuum signal so that vacuum accessories can operate under low manifold vacuum conditions.
If the cam is so aggressive as to not maintain proper manifold vacuum, you may need to go to a manual valve body. |
it's an ISKY 525/308 MEGA cam. I also have a 3500 B&M Holeshot conveter. Just a pain right now.
I had an extra vacum tank, it did not help. I also had power brakes. It had problems when you first start up and when you hit the brakes. I read about electric vacum pumps. I never tried one but looks like the solution.
Will |
[quote]Originally posted by Will's41:
<strong>I had an extra vacum tank, it did not help. I also had power brakes. It had problems when you first start up and when you hit the brakes. I read about electric vacum pumps. I never tried one but looks like the solution. Will</strong><hr></blockquote> A frind of mine has a olds cutlass he had this problem he used a anti leveling off of a 1979 Buick Riveria and it works great |
