Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vaccum reservoir
Old 02-16-2003, 03:26 AM
dklong's Avatar
dklong dklong is offline
Post
I think you should try a adjustable modulator vavle in your trans and how big is your cam ??? you'll probable need a high stall torque converter . contact b& m , tci , or jegs or a performance shop. tell them about what you are doing with your car , engine size , gear ratio, tire size, and cars weight. with this info they should be able to give you the right stall speed for your combination.
