vacum - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2012, 08:36 PM
vacum
high i have a 1983 bax caprice that i just did a motor swap to took out the lil 305 and dropped in a built 400 sbc that i cant get the vacum lines right or going to the correct spots help me please
Old 01-13-2012, 09:32 PM
gonzo08383's Avatar
Last journal entry: brakes
what kind of carb you running? transmission?
Old 01-13-2012, 09:59 PM
I have a 350 turbo tranny and su cheap elderbrock carb with electric choke
Old 01-15-2012, 06:32 PM
gonzo08383's Avatar
the manifold vacuum line goes to ur trans modulator. the timed vacuum port goes to your distributor. the big line on ur carrb goes to ur brakes. i personally plug the one on the front and use the one in the back. timed vacuum is the port above the throttle plates. as engine speed increases so does the amount of vacuum of the port which pulls ur modulator on ur distributor to add timing. the small vacuum port lowest on ur carb is manifold vacuum.
vacum hemi joe Engine 5 07-18-2009 10:17 AM
vacum 79chevy4x4 Engine 6 12-13-2006 10:21 AM
Need Help !!! More Vacum Please!!! 355 Chevy Guy Engine 9 04-06-2006 09:33 AM
Gas in vacum can NovaSS350 Engine 2 05-23-2005 10:02 AM
Vacum or not? HemmiGremmie Engine 3 05-27-2003 06:21 PM
