vacume advance or mechanical advance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2009, 06:54 PM
BigBlockT's Avatar
Last journal entry: recessed lisence plate
question I have access to a high dollar mechanical advance distributor for next to nothing is it worth useing on a stock to mild bigblock chevy in a streetrod not a drag car?
Old 06-08-2009, 07:05 PM
ericnova72's Avatar
More for Less Racer
You could use it but gas mileage, spark plug, and oil life will suffer and the engine may run hot at cruise and low speeds because of the lack of vacuum advance. There is no good reason to go without vacuum advance, only good reasons to use it.
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 05:10 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
detonation 71 chevy c-10 Engine 33 04-29-2010 12:20 PM
vacuum advance help batman09 Engine 14 09-09-2004 09:42 PM
Mechanical Advance settings...... black66 Hotrodding Basics 12 08-28-2004 02:35 PM
