vacuum 307 L chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2008, 08:56 PM
vacuum 307 L chevy
I replaced my carb on my 1971 chevy 307 with a 1973 carb there not exactly the same the 1973 has a threaded hole in the back side closest to the firewall near the base of the carb does anyone know what this hole is for and if i can plug it also there are more vacuum ports on the new carb
Old 06-24-2008, 11:07 PM
life is a temporary assignment
Welcome aboard !!!!!!
Old 06-25-2008, 05:11 AM
poncho62's Avatar
Wiki Edits: 5
moving to engine forum
Old 06-25-2008, 05:04 PM
The threaded hole on the back side of the carburetor (I assume its a quadrajet) is for the line to the power brake booster. You can plug it if you don't have power brakes.
The three ports on the front of the carb are usually the PCV valve (larger diameter line), vapor recovery canister (usually on driver's side), and line to the vacuum advance (probably ported vacuum, but might be manifold).
Bruce
Old 06-25-2008, 08:54 PM
thanks bruce
wow you rock vacuum was the easy part the hole however had me stumped i do not have power brakes so now i feel better about just plugging it thanks man
307 Chevy build-up JAKE 68 GMC Engine 18 01-26-2012 11:37 AM
454 Ignition Timing Question leejoy Engine 56 09-13-2008 08:40 AM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
running no vacuum advance oregon chevelle Engine 28 02-07-2007 07:17 PM
No ported vaccum port in my Q-jet, help Augusto Engine 11 12-27-2006 05:04 PM
