vacuum advance - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2011, 09:10 AM
vacuum advance
I have a 454 Big Block-oval port heads-Crane cam (specs unknown)-edelbrock intake-holley 750 double pumper-hooker headers and a newly installed msd street fire hei distributor. the car has a muncie m21 4 speed.
Here is my problem;
Since I have installed the distributor-with the vacuum advance connected-I get an idle that goes up to 1500 rpms and then drops down to 600. It continues to do this no matter how I set the carb idle.
When I block the vacuum lines i get a consistent idle but have a noticable "miss" at around 3000 rpms. I have also installed a new set of AC Delco Rapif Fire sparkplugs and the wires are new MSD. The car also pre-ignites (keeps running slightly after shut off).
I have attempted to adjust the vacuum advance but am unable to locate the set screw within the vacuum cannister.
I have no problem running the car without the vacuum advance.
Help!!
Old 04-14-2011, 09:17 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The advance weight springs may be on the verge of advancing at idle, and when they do- the idle speed increases.
So, try one step heavier spring on ONE side of the advance mechanism. Hopefully adding that bit more spring will keep the advance from coming in at idle speed.
IF the vacuum can is adjustable, the screw should be inside the vacuum port. If you can, see if it's an allen type (usually 3/32") or possibly slotted for a screwdriver.
Old 04-14-2011, 10:14 AM
Here is my problem;
Help!!
This sounds like one of a couple three things perhapes in combination.
If you're taking the vacuum signal off the carb's timed port and the throttle blades at idle are right at the threshold of exposing this port, it could be switching back and forth between off causing a low idle and on causing a fast idle.
Run on is usually a sign that the mixture is too lean at idle which runs the temps in the combustion chamber up to where something glows hot enough to keep the engine running. There are electric solenoids sold for the purpose of completely closing the throttle blades when the ignition is shut off which stops this habit. A colder range spark plug might help with no other changes, so could running the idle mixture screws out a little. A failed or disconnected EGR can cause this. The fuel mixture goes to lean unless adjusted when the EGR is failed or removed.
Curb idle needs to be set with the vacuum advance function unless this engine has a radical cam. For a mild cam use the full time vacuum port, for a radical cam use the timed port in this case it makes the engine easier to get started.
The throttle at idle must be below the transition slots, look in the carb's lower venturi bore you will see a rectangular slot, at idle the top of the throttle blade needs to be no higher than the bottom of this slot. If that doesn't provide sufficient idle air then the primary throttle blades can be drilled with a very small bit, if this is a Holley the secondary throttle blades have an adjustable closed stop that can be used to crack the blades a bit.
The 3000 RPM miss can be anything from a lean hole in the carburation to a poor transfer of timing advance such as the vacuum not going out quickly enough of the centrifugal coming in too soon or too late such that there is a moment of either too much or too little advance.
Bogie
Opinions on ported of full vacuum for vacuum advance ? y2k600f4 Engine 13 10-07-2011 09:38 PM
Timing... vacuum or no vacuum advance? 454ChevelleMalibu Engine 17 04-25-2010 09:37 PM
adj. vacuum advance ss396si Engine 2 09-29-2009 09:11 PM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 02:25 PM
computer advance or vacuum advance?? 1984camaroZ28 Engine 1 10-12-2002 02:57 PM
