vacuum advance - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2011, 06:56 AM
vacuum advance
I have a 355 engine w/hei that the timing is advancing to much when the vacuum hose is reconnected after setting the timing. Anyone use an adjustable vacuum advance? If so which one (accel, summit, etc.) and does it do the job?
Old 04-30-2011, 07:15 AM
cool rockin daddy's Avatar
Put "HEI tuning" in search box for this forum. bottom right hand side of page. Many answers to your query.
Old 04-30-2011, 09:03 AM
sqzbox's Avatar
My pipes are my music
It sounds to me like you have the vacuum hose hooked up to a full time vacuum port. You need to try and find the metered port and hook up to it and see if you get the results your looking for before you invest in an adjustable vacuum can. If you don't have a vacuum gauge, you can find the metered port by capping off the port you have your hose hooked to now and un-cap another port on the carb. that doesn't affect the idle speed when you take the cap off. That will be the metered port. The adjustable can doesn't control how much advance you get at idle but, it does control how soon the advance comes in.
Old 04-30-2011, 09:08 AM
Really suggest you read the article "HEI tuning" before you make the mistake of running ported vacuum.
Old 04-30-2011, 09:25 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the tip-in point is acceptable and all you need to do is limit the total amount the vacuum advance adds in, use a vacuum advance limiter plate like the Crane #99619-1, #99619 Instructions. Or you can make one.
On a performance SBC engine, 10-12 degrees added by the vacuum advance works out about right. This is providing the mechanical advance curve is correct.
Old 04-30-2011, 04:22 PM
sqzbox's Avatar
I try the best with what I've got and there's a whole lotta info missing other than it's a 355. Running full time vacuum advance is not chiseled in stone and depending on how and what you drive has a lot to do with it.
That ported vacuum port wasn't put on carbs to run the heater controls.
Old 04-30-2011, 10:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I have found that a stock engine (i.e. high vacuum) might not run any better w/the vacuum advance hooked to manifold vacuum. The bigger the cam duration/overlap is, the more the engine seems to 'like' manifold vac., IMO.
Old 05-01-2011, 06:27 AM
This engine is 355cid with a GM(crane) solid lifter cam (459/485), 492 heads, GM winters alum intake and Holley 750 cfm w/vacuum secondaries with the pistons I have and heads resurfaced make for about 10.5 to 1 compression ratio. to get 38* total timing(3000rpm) I end up setting the initial timing at 23*(800to1000rpm) with the vacuum advance disconnected, when I reconnect the vacuum hose the timing goes to 38* at idle(800 to 1000rpm) I would like about 8* to 10* advance not 15* I know the initial timing is higher than I would like but around 20* should be acceptable (I hope)
Old 05-01-2011, 07:07 AM
sqzbox's Avatar
OIC now, that's a race engine! I can see using full time vacuum now. OR, you could go with a full mechanical centrifugal advance dist. and eliminate the vacuum advance all together.
Old 05-01-2011, 07:25 AM
No its a 1970 LT1/ Z28 engine in a 1985 S10 Blazer 4x2, not a daily driver but a not a race car either, just for fun!
Old 05-01-2011, 07:34 AM
sqzbox's Avatar
Don't make any difference. Once you changed the cam everything changes.
That's why your having a problem getting the advance set up the way you want it over the way it was. I had a friend with a 70 Z LT1 and it was awesome to drive. I can imagine what it's like in your S-10 blazer. Probably scare me!
Old 05-01-2011, 08:32 AM
Thanks to everyone for the input, the crane kit or making something to limit the travel of the vacuum advance rod is probably my best bet since I don't want to completely remove it just have less vacuum advance.
Old 05-01-2011, 10:03 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
For complete adjustment and setting this kit is available:
http://www.summitracing.com/parts/CRN-99600-1/
Its good quaility stuff
It includes the limiter plate cobalt mentioned as well as an adjustable can which will allow you to fine tune the vacuum advance rate as compared to engine vac be it ported or manifold.
It has some mechanical/centrifugal advance curve springs too which may come in handy.
Opinions on ported of full vacuum for vacuum advance ? y2k600f4 Engine 13 10-07-2011 09:38 PM
Timing... vacuum or no vacuum advance? 454ChevelleMalibu Engine 17 04-25-2010 09:37 PM
Vacuum advance western star Engine 14 11-30-2009 10:28 PM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 02:25 PM
computer advance or vacuum advance?? 1984camaroZ28 Engine 1 10-12-2002 02:57 PM
