Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vacuum Advance Canister question
Old 04-15-2008, 09:14 PM
strokey strokey is offline
Techron - I'd love to have the link, Ive been reading old posts for hours trying to diagnose.
I think I've finally narrowed the problem.
I spent time blaming my sour performance on the stock stall converter and stock highway gears, then the swap meet 650 holley double pumper with a kit in it.
I bought a brand new box stock holley 670 and noticed much crisper throttle response in park, yet the same completely no idle/stall when in drive.
I'm running a 388 ci sbc with a comp xe284h. The car makes 6-7 hg" of vacuum in gear at 800 rpm's.
Ive been blaming the drive train/running gear for the high idle it needs in park in order to sustain a sufficient idle when placed in gear. Here is what I think my problem is.
The car has a real sweet attitude idling at 1300 in park. This is probably at the point where it is producing a good ammount of manifold vacuum.
When the car is placed in gear the rpm's drop and it immediately falls on its face and stalls.
I think this is because of the non adjustable factory style advance canister. It is providing no advance in drive ( at 600-800 rpm's, again making 6-7 hg" of vacuum).
In a nutshell to even have the car driveable I was running at 1300 rpm's in park. I have now realized that at this point (in park) the vacuum advance is running at full clip providing an additional 15 or so degrees of timing, thus a total of around 27. Then when you switch to drive and the rpm's drop (as well as manifold vacuum levels) you are back to the base timing of around 12 degrees (because the canister is providing little or no advance at this point with such a low ammount of vacuum).
Simply there is no happy medium with this cam and this advance canister with this configuration.
I need an adjustable can badly.
I may be preaching to the quire.
But someone please let me know if I am on the right page.
