Vacuum advance is strickly for fuel economy. If your engine can use it then it should be hooked up.A holley anything is not likely the best carb for mileage,they are better known for power
| The Following User Says Thank You to vinniekq2 For This Useful Post: | ||
LEROYDOZOIS (09-01-2012) | ||
i figured
whenever i would be changing a carb on the suburban or something like that nature he would run over and tell me how hes a carb master and that his boat doesnt use any gas and that he could build me the perfect carb
i dont trust him with my mechanical pencil let alone a carb lol =] |
Be sure the advance is actually working. Often the original vacuum advance units are no good by now, being as they've not been installed on an HEI distributor for many years. |
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
LEROYDOZOIS (09-02-2012) | ||
Also, anyone who so loosely makes a statement such as "disconnecting your vac advance gives you better mileage", should never be trusted to rebuild anything on a motor vehicle.
yeah
![]() and 327. thanks for the link ill read it when i have down time at work. timing on the truck should be correct but ive kinda wanted t ocheck the ( total timing ) i think its called, i saw a thing on here before and used it when i was doing the timing on the truck, but i like to double check =] |
So now this goes back to your other thread where I asked where your timing was set. Was vacuum advance in use? Was it connected to a manifold source? You never did tell me what the timing was set at, other than you saying somebody else said it was okay. The base timing should be 12 degrees before top dead center with vacuum advance disconnected and plugged. After it's set lock the distributor. Connect the vacuum advance to a manifold or full time vacuum source (one that pulls vacuum full time including idle)
Now recheck the timing, it should be 18 to 24 degrees before top dead center. When you connect the vac advance right away it's going to idle up. This enables you to further lower the idle speed, placing the butterflies back on the idle slots on the carb. As the other guys have said vacuum advance is very important from a mileage stand point. It's also very important in relation to other things such as idle quality, idle speed, and yes without it in use the engine will run hotter and in some cases run hot. Many have asked what use vacuum advance at idle? There are several reasons, one of those is idle and off idle mixtures, such as at cruise speeds the mixture is lean. Lean mixtures burn slower than do richer ones. Due to lean mixtures burning slower more timing advance is needed. Another reason is try and set the base timing at 24 degrees without the aide of vacuum advance, kick back, starter dragging with broke starters will result as there is no vacuum when trying to start the engine so the engine only "sees" 12 degrees before top dead center until it starts. with the base timing at 12 degrees or lower without vacuum advance another side symptom is poor throttle response. You can have a nice small block with excellant components to make lots of low end torque and without the correct spark advance it will be a powerless slug that drinks gas. I've been down this road several times and that's how I got to where I am now. I was told and I learned. It taught me my brother is right, there is no substitute for experience. |
| The Following User Says Thank You to DoubleVision For This Useful Post: | ||
DoubleVision is right on target... There are MANY postings on the internet that argue the issue of ported vacuum (no vacuum at idle) and manifold vacuum (constant vacuum). The engine will run better, cooler, more effecient, faster and just about everything positive that is not mentioned when running off of manifold vacuum to the vacuum advance. Either take the vacuum off of the base of the carburetor or off of the intake manifold and your vacuum will do the rest. What ever your timing spec is, it will increase 12 - 14 degrees at idle when the manifold vacuum is applied. After modifying the vacuum source, readjust your idle and idle mixture screws and reset your idle again. Ported vacuum was introduced prior to the cat when polution control started controlling emissions. Instead of BTC (before top dead center), we went to ATC (after top dead center) and ported vacuum was required. Without all of the emissions on street built engines, ported vacuum is no longer needed.
| The Following User Says Thank You to 1brewmaster1 For This Useful Post: | ||
| Opinions on ported of full vacuum for vacuum advance ? | y2k600f4 | Engine | 15 | 10-07-2011 09:38 PM |
| Timing... vacuum or no vacuum advance? | 454ChevelleMalibu | Engine | 18 | 04-25-2010 09:37 PM |
| Vacuum advance full of fuel... | 04SilveradoMykk | Engine | 1 | 06-23-2009 09:39 AM |
| ok to use same vacuum line for vacuum advance and tranny vacuum modulator? | brian400ex | Engine | 4 | 02-19-2003 02:25 PM |
| computer advance or vacuum advance?? | 1984camaroZ28 | Engine | 1 | 10-12-2002 02:57 PM |
