Vacuum advance full of fuel... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2009, 08:27 AM
04SilveradoMykk's Avatar
Hey Guys,
I just put a Echlin VC1810 vac can on on the Summit dist I'm using on my SBC, I've driven it for two days and this morning I just pulled out the dist so I can set it up on a buddies Sun dist machine.
The good news is I finally got the gear wear pattern to look right, but when I removed the dist I had to let the vacuum advance drain for a while because it was full of fuel... Is my solution as simple as making a new vacuum line that has a dip upwards higher than the vac ports to prevent fuel from making it that far?
The vac can is hooked up to the manifold vacuum port on a Demon 650cfm.
Cheers ~Mykk
Old 06-23-2009, 09:39 AM
DoubleVision's Avatar
My vac advance did the same thing when I was using a demon. It`s never happened to me using any other carb.
All I did was switch vacuum ports. I ran the vac advance to the manifold outlet behind the carb and used the full time port on the demon to control the A/C ducts.
Locking full centrifugal advance and vacuum question bubbahotep Engine 26 08-12-2008 09:23 AM
Timing/carb idle mixture adjustment DENCOUCH Engine 7 07-21-2008 11:50 AM
vacuum vs mechanical advance on street SB chevy 389TriPower Engine 6 05-05-2008 09:28 PM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
No ported vaccum port in my Q-jet, help Augusto Engine 11 12-27-2006 05:04 PM
