Vacuum Advnace - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2005, 10:37 AM
Vacuum Advnace
I am trying to set the advance curve on my 351W in the Mustang, but I am having some problems. The distributor is a stock Duraspark. I have been able to set the centrifugal to 20 degrees full in at 3000 rpm. When I connect the vacuum, total advance goes off the chart - I'm guessing past 55 degrees with the 14 degree initial. How can I limit the vacuum advance to ten degrees or thereabouts? With that much total advance it does concern me that maybe it's TOO much.
Old 09-05-2005, 12:41 PM
Canzus's Avatar
a red wool sock on his dinger
Are you sure you need the vacuum advance??
My 289, mechanical is all in 2800rpm, with 16*
initial, for a total or 36*. Seems to run just
fine all the way to redline. When I hooked
up the vacuum advance, to ported vacuum, not
manifold vacuum, it rattles and pings rather
badly. So I plugged of the port...
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 05:10 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
vacuum advance help batman09 Engine 14 09-09-2004 09:42 PM
