Vacuum booster check valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2008, 05:27 PM
chevy3600's Avatar
http://community.webshots.com/
There is a tag on my booster that tells me the warranty is void if the check valve is removed. How would removing the check valve affect the booster and void the warranty?
Old 02-23-2008, 05:39 PM
re: vacuum booster check valve
Hi the check valve is so that pressure only goes one way, then there is a relief valve after the check valve, with out the check valve, pressure can go both ways, then you got problem, brakes don't work right or at all, in some places it is against the law to remove TROY
Old 02-23-2008, 06:00 PM
The check valve also protects the diaphragm in the booster from an intake backfire. Without the valve, the pressure pulse could rupture the diaphragm.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
vacuum booster is it working Ed ke6bnl Suspension - Brakes - Steering 2 10-15-2004 04:39 AM
vacuum brake booster 48Man Suspension - Brakes - Steering 1 01-14-2003 06:10 AM
hooking up a heater control using vacuum valve HotRodF100 Hotrodders' Lounge 5 03-31-2002 05:18 PM
