Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vacuum booster check valve
Old 02-23-2008, 06:39 PM
troy norrad troy norrad is offline
re: vacuum booster check valve
Hi the check valve is so that pressure only goes one way, then there is a relief valve after the check valve, with out the check valve, pressure can go both ways, then you got problem, brakes don't work right or at all, in some places it is against the law to remove TROY
