vacuum brake booster - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2003, 05:50 AM
48Man's Avatar
Post vacuum brake booster
I have tapped into the booster vacuum source at the pleunm on an LT1 engine. I teed off to vent my distributor. The dist. hose goes from the tee thru the dist and then inside the car to a small filter. This gives air flow thru the opti spark to keep it dry. My question is, do you think this will effect my booster performance. I should have it running today if the weather cooperates and find out for myself. <img src="graemlins/sweat.gif" border="0" alt="[sweat]" />
Old 01-14-2003, 06:10 AM
aka Duke of URL
Arrow
Should have no effect at all as long as you have a minimum of 18" at the booster.
