Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vacuum Canister?
Old 06-25-2009, 06:32 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Originally Posted by 84TA406
Well if I could fit a spacer I would believe me, I'll head to the hardware store tomorrow and see what I can come up with fitting wise.
Thanks for the help.
Any clue how expensive it is swapping to hydroboost brakes?
Bolt on Hydroboost kits can be fairly expensive. If you piece the parts together yourself it can be done much cheaper. Many use the Astro van Hydroboost unit with correct sized master cylinder and then do your own plumbing. Most of what's needed can be found on Ebay.
