Vacuum canister - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2004, 09:21 AM
New Member
Vacuum canister
Hey folks john law says I have to have the charcoal vacuum canister hooked up to pass inspection. It is located in the front passenger corner of the motor comparment. It has 3 places for hoses to go but I have no Idea where they go do any of you?
Thanks
Old 03-26-2004, 05:44 AM
302 Z28's Avatar
Usually the charcoal canister is to absorb gasoline fumes coming from the tank and carb. You should have a line from the tank and one from the carb airhorn.
Vince
Old 03-26-2004, 06:32 AM
aka Duke of URL
You are most likely going to have to find the correct year shop manual or parts blowup for the installation detail. You will have one purge line from the carb to the cannister, a vacuum supply and a return vent hose to the air cleaner asm plus the return line (usually steel on a FORD) to the tank.
You also will have a purge solenoid and a one way vacuum valve in the purge line. He's probably is going to want the complete vent system restored.
Maybe you could get lucky and find a setup in the junk yard.
Old 03-26-2004, 06:37 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Year, Make, and model????
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
