vacuum diagram - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2010, 07:25 PM
whojohnjones's Avatar
vacuum diagram
anybody know where could I find a free vacuum diagram for a 1983 Buick parkavenue?
Old 10-28-2010, 08:32 PM
LATECH's Avatar
I think www.autozone.com has them for free.
I remember the vac system on the E4MC carbs . They were like a chinese jigsaw puzzle. good luck
Old 10-28-2010, 08:50 PM
can't seem to locate em there
Old 10-29-2010, 01:33 AM
This is as close as I can get.
File Type: pdf A-Body 3.8L VIN 3 TBI - 1984 Federal models.pdf (11.8 KB, 94 views)
Old 10-29-2010, 03:35 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Maybe your local library.
Old 10-29-2010, 04:41 PM
LATECH's Avatar
The library as someone suggested may have a motors manual you can check out or copy the page so you dont have to worry about greasin the pages or returning the book 4 years late and paying a fine.
Try an emission motors manual if they have one. If not you may have to go to autozone to get them to print it off for you.
Also your local buick dealer will probably have it. Talk to a service manager he might be kind enough to oblige.
Old 10-29-2010, 05:02 PM
ok I should just tell the problem..I have removed all the olds 307 and all emissions components..now i have two vacuum lines from the dash for vents..maybe a gm person knows alot about this. how would I hook up vacuum lines to 350 engine
Old 10-29-2010, 05:56 PM
LATECH's Avatar
Hook a hose to manifold vacuum and then to a one way check valve then put A Tee in line . hook one to a vacuum storage canister and the other to the feed to the HVAC control. There are 2 hoses I know. One of them comes from the HVAC controller to the hot water control valve for the olds motor.The other one is the supply for the control.Try it one way and check for dash vent and defrost and foot vent etc. If it doesnt work switch the hose and check again.
Old 11-04-2010, 08:41 PM
fast68's Avatar
likes chevy trucks & boobies
one is for full time intake manifold vacuum source to run the HVAC control panel.
when you have it right you will be able to hear positions change via vacuum sounds noises in the heater boxes with engine running/idling, unless the control assmebly is broken or leaking vacuum badly
the other is for flow valve in heater core hose
pretty easy simple
the latter one you dont need, ignore it, plug it with a small screw
do away with the valve in the hose
done.
help a newb time his 355 jarrettandroski Engine 1 07-05-2009 12:22 PM
454 Ignition Timing Question leejoy Engine 56 09-13-2008 08:40 AM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
vacuum diagram spellmakerw Engine 2 05-06-2002 12:13 PM
