Vacuum diagram help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2007, 04:12 PM
Vacuum diagram help
I need help with the vacuum on my truck. Now I have a 82 chev 3/4 ton that had a 6.2 diesel in it. I got it with a 350, and put another 350 in it. I put in a 68 camaro 350 but I have a hei distributer. I have no vacuum hooked up to the vacuum advance on the distributer, buecause when I hook it up to the carb, the diaphram on the distributer pops with reving the engine. I only have a vacuum from the tranny to the manifold, and from the pcv to the carb. I also have a vacuum from my carb to a vacuum unit for my heater controls. I need to know what the proper vacuum or best for my truck would be. Ohhh I am using a rochester quadra-jet carb and I have a edelbroc performer manifold. Thanks
Old 03-17-2007, 06:48 PM
docvette's Avatar
Wiki Edits: 12
Originally Posted by agent spliff
I have no vacuum hooked up to the vacuum advance on the distributer, buecause when I hook it up to the carb, the diaphram on the distributer pops with reving the engine. Thanks
Doc here,
Please Clarify, When you say "Pops" Do you mean it spits fire out the intake or Exhaust..OR the distributer makes a metallic noise?
Two very different issues.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 03-17-2007, 07:10 PM
distributer makes a noise. It sounds like it is comming from the vacuum on the distributer. When I disconected the vacuum from the carb to the distributer, the distributer stopped making noise. When I hook it up, it makes a metalic poping from the distributer. So yea it is pretty much a metalic noise at the distributer. I am not sure what the problem is. Sorry if I am being a pest Doc, Thanks
Old 03-19-2007, 01:23 AM
Could it be something rubbing inside the distributor, but only when the vacuum advance is engaged?
I generally prefer manifold vacuum like pre-smog engines had, but from what I hear, some of the HEI's have way more vacuum advance than the older distributors had.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 12:19 PM
No ported vaccum port in my Q-jet, help Augusto Engine 11 12-27-2006 06:04 PM
68 charger lights T-bucket23 Electrical 5 08-14-2006 06:07 PM
