Vacuum Gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2009, 05:49 AM
UngerMarkus's Avatar
TuckīnīRoller
Vacuum Gauge
I recently installed a NOS dash mounted vacuum gauge in my '64 Bonneville. But the readings seem to be wrong. I get 11 hg at idle, so the needle is in the middle of the scale (marked orange). As soon as Iīm driving, I just get 8 hg (marked red).
Even when rolling downhill with the foot off the gas pedal the needle wonīt reach the green side of the gauge.
I connected the vacuum line to the left port of my qjet (when standing in front of the engine). I used a gas-hose with 0.1'' inner diameter.
Could this be the reason for my false readings?
thx
Markus
Old 07-30-2009, 09:02 AM
Last journal entry: frame build
It needs to be connected to manifold vacuum. If memory serves, the line should be 3/16". Find someone with a mitevac hand pump to check accuracy of the gauge. They were notoriusly inaccurate, but were eyecandy anyway. I have several and would put good money on none of them reading the same.The factory tach guys love them cause the tach fits the same housing and vac housings usually aren't scratched up so bad.
Incidently, a warm cam will throw the reading way off.
Old 07-30-2009, 10:32 AM
TuckīnīRoller
Thanks a lot 61bone!
Does anybody know how much vacuum I should have at normal cruising conditions? Itīs a stock 301 pontiac V8.
Old 07-30-2009, 11:17 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Just normal cruising, holding a steady throttle, and your engine being stock, it should show between 17-19. Also, right after you take your foot off the pedal it should jump above 19, and into the low 20's.
Retarded ignition timing will lower your intake manifold vacuum, and I would suspect the vacuum advance on your distributor is bad, or it is hooked to a ported vacuum source.
Make sure you have it hooked to a manifold vacuum source, and unplug it listening for the engine idle speed to drop. If not it is bad, and causing a vacuum leak.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
help a newb time his 355 jarrettandroski Engine 1 07-05-2009 01:22 PM
Vacuum Gauge in Tpi fuelslut Engine 6 02-12-2009 10:30 AM
454 Ignition Timing Question leejoy Engine 56 09-13-2008 09:40 AM
Vacuum adv.. underdog305 Engine 58 01-30-2007 12:19 PM
