vacuum gauge needle fluctuating really fast - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2010, 10:53 PM
i have a car missing at higher rpms. the vacuum gauge is fluctuating between 18 and 12. the needle moves really fast between these two numbers. car seems to idle fine
Old 05-20-2010, 11:14 PM
DoubleVision's Avatar
Then it`s losing one of several possible things. Spark is falling off, fuel is falling off, valve springs are worn and have reached there limit, or camshaft has reached it`s RPM limit.
Old 05-21-2010, 12:04 AM
sqzbox's Avatar
My pipes are my music
What is the gauge doing at idle?
Old 05-21-2010, 06:06 AM
Last journal entry: Some More Roll Cage Fabrication
Sounds like a broken spring or valve bounce from worn out springs. A spark issue or fuel issue will lower vacuum but not make it bounce rapidly. If you have headers and an infared gun you could find the cold cylinder and test those springs first. Fix it now before you burn a valve! Good luck.
Old 05-21-2010, 06:54 AM
cboy's Avatar
Last journal entry: Finished
Here's a quickie reference sheet on reading a vac gauge. http://www.centuryperformance.com/tu...e-spg-148.html
Always learning...and sharing what I've learned.
help a newb time his 355 jarrettandroski Engine 1 07-05-2009 01:22 PM
454 Ignition Timing Question leejoy Engine 56 09-13-2008 09:40 AM
Bouncing fuel gauge needle 1970Chevy General Rodding Tech 9 07-09-2007 02:07 AM
Ported Vacuum 72Orange Engine 18 08-07-2006 09:56 PM
Vacuum questions screamin340 Engine 1 01-26-2004 09:34 PM
