Vacuum Gauge reading, can you help me interpet them? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2004, 11:40 PM
Jag Daddy's Avatar
British Style with USA Muscle
Tonight I went out and hooked up my new vacuum gauge to the back of the carb, I was reading about 19.5 inches after the engine came up to temp. I did notice that it would bounce slightly between 19 inches and 19.5 inches. I read somewhere that it should read steady and it if bounced around it could be timing or carb out of adjustment.. Which should I check first?
If I need to adjust the timing what the easiest way to do it with an HEI with out getting bit?
Regards
Mark
Old 04-16-2004, 06:33 AM
Steve karch's Avatar
http://www.centuryperformance.com/vacuum.asp
Try this site, I don't think you have anything to worry about though.
Steve
Old 04-16-2004, 07:07 AM
camaroguy_1967's Avatar
Air Trans
Hey thanks for the link. I had been trying to figure out why the needle would vibrate at idle the get steady with rpm increase. Worn valve guides, GREAT! Had some rockers loose and adjusted them some what fixed the fluctuation. Thanks again!
Joe
