Vacuum Gauge in Tpi
Hi there :
I'm rebuilding a LB9 (305 tpi from a 88 chevy), i'm planning to hook-up a VAC gauge to check Vacuum. I'm gettin' confused .... where i can attach the fitting for gauge ? , in a carbed engine it's so easy , but there i'm gettin' stuck, i'm new on Fuel Injections. Here's a VAC diagram of the engine. Any ideas ? Cheers , JF |
It will be for permanent use , attached to a gauge in dash , how i can install this additional vacuum port ? it's a easy thing or a pain the *** ?
Thanks for your answer . Cheers , JF |
Here some pics of the ports. The pic on the left show the pcv hookup on the drivers side. The other shows three ports. The one with the hose goes to the AFPR, i'm not sure where the other ones go.
One from right picture , should go to brake booster , chech the diagram on my first post ![]() In mine, i don't have free vacuum ports to attach the "T Fitting" for gauge , any suggestions ? I had to install a new VAC port ? Cheers , JF |
i'll research on it! Cheers , JF |
| Port or Full time vacuum | cool rockin daddy | Engine | 129 | 10-05-2010 03:00 PM |
| timing question | Radchop | Engine | 7 | 11-19-2008 09:16 PM |
| No ported vaccum port in my Q-jet, help | Augusto | Engine | 11 | 12-27-2006 05:04 PM |
| Ported Vacuum | 72Orange | Engine | 18 | 08-07-2006 08:56 PM |
| Where is manifold vacuum port on Quadrajet 4mv? | dr-data | Engine | 10 | 12-13-2005 04:41 PM |
