If its in that nice pickup there then you may only need a few essential vacuum connections, decide what you want to keep for accessories and post them devices.
Stock trim there are temperature activated switch valves, diaphragm valves, egr crap etc etc. You may not want that or maybe u do Bare bones may look like distributor to carb, intake manifold/carb to power brake only,,,hard to tell from here, the hood is shut
You truly only need two pickups, one is ported vacuum for the distrib advance and the other is full port vacuum for the power brakes. The power brakes connects to the large fitting on the rear of the manifold (full vacuum) and the distrib ported vac source is on the carb...easy to find which one it is with the engine running...it has little to no vacuum when the engine is idling but gets vacuum once the throttle plates open up.
Unless you have vacuum operated accessories everything else can be blocked off, the 67 engines didn't have any EVAP devices or temp controlled distributor vacuum switches so it should be easy. If you want more detailed advice a picture of your existing setup would be necessary.
Outlawed tunes from outlawed pipes |
So basically,
The large one in the back is full vacuum. That one goes to the valve cover Im almost sure. Then the other to the vacuum advance on side of carb. Everthing else can be capped off? I would like a pic if ya got one 4 JAW CHUCK! Thanks for your help guys! |
the distributor vacuum advance is sometimes plugged into full time vacuum port and sometimes into the part time ported vac port on side of carb. i like dist plugged into full time vac for saucy cam and ported vac for mild cam. can try both to see which works better. |
| Vacuum modulator hookup for automatic | 65malibuSS | Transmission - Rearend | 2 | 11-29-2010 10:27 AM |
| Coil problems 1967 Firebird | billme83 | Electrical | 5 | 03-19-2010 07:22 PM |
| distributor vacuum hookup | highway star | Hotrodding Basics | 6 | 06-16-2005 06:15 PM |
| vacuum problems | APACHEMAN | Engine | 3 | 09-29-2004 11:32 AM |
| 1967 Stalling Problems | Stangman196700 | Engine | 8 | 12-04-2003 07:11 PM |
