Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vacuum hookup on T-400 transmission?
Old 02-08-2013, 11:58 AM
Juleshulings Juleshulings is offline
also I took out a 700 and it had a three wire plug on the side that the kick down is on the 400 . should I remove those wires or would it be ok to leave them? if should remove them would you know where they are hooked up at.. i tried to follow them but it is a jumbled mess!
