Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vacuum hookup on T-400 transmission?
Old 02-08-2013, 08:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Juleshulings View Post
thank you very much!! I got her up and running!!the only thing is I have put the recomended amount of tranny fluid in and it is not showing up on the dip stick? should I add more?
As long as the dipstick is correct for the tranny and tube, add until it's at the bottom of the cold level. Check again after the tranny is hot and add if needed.
Check with the engine running. Shift through all the gears then back to park. Wipe the dipstick and check the level- engine running still.
The Following User Says Thank You to cobalt327 For This Useful Post:
Juleshulings (02-09-2013)
