Vacuum hookup on T-400 transmission?
I was wondering if some had a picture of where to hook up the the vacuum modulator to the manifold? I replaced the transmission in my 89 suburban with an th 400 and need to hook up the vacuum modulator but not sure where is the best place to hook it up at. a picture would be nice.
thank you for your time
wires
also I took out a 700 and it had a three wire plug on the side that the kick down is on the 400 . should I remove those wires or would it be ok to leave them? if should remove them would you know where they are hooked up at.. i tried to follow them but it is a jumbled mess!
thanks
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
Juleshulings (02-08-2013) | ||
thank you very much!! I got her up and running!!the only thing is I have put the recomended amount of tranny fluid in and it is not showing up on the dip stick? should I add more?
Check with the engine running. Shift through all the gears then back to park. Wipe the dipstick and check the level- engine running still. |
Juleshulings (02-09-2013) | ||
| Tags |
| manifold, th400, transmission, vacuum |
| vacuum to the transmission | mbaskettjr | Transmission - Rearend | 1 | 09-08-2011 03:52 PM |
| TPI throttle body vacuum hookup | Fat 48 | Engine | 3 | 07-11-2011 12:33 PM |
| Vacuum Hookup problems on a 1967 289 | jsm1847 | Engine | 7 | 03-31-2011 10:26 AM |
| Vacuum modulator hookup for automatic | 65malibuSS | Transmission - Rearend | 2 | 11-29-2010 10:27 AM |
| distributor vacuum hookup | highway star | Hotrodding Basics | 6 | 06-16-2005 06:15 PM |
