Vacuum Hoses - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2010, 01:38 PM
Shag0215's Avatar
Tha Shag
Vacuum Hoses
I Have a Holley Contender Intake and it has one port for vacuum and i was told not to tee any vacuum lines. Where should i route my modulator valve line and my advance on my distributor
Old 03-08-2010, 03:36 PM
dizzle217900's Avatar
Runnin' Down The Dream
Last journal entry: 1941 Dodge Pickup
vacuum hoses
If your carbs base plate has a port you can use it for the distributor. I think that holly carbs have manifold vacuum ports on them if it is below the butterflys then it is probably manifold vacuum.
Old 03-08-2010, 05:48 PM
Sinister's Avatar
You can tee off of vacuum lines. My '69 Chevy C-20 had a tee from the factory for the transmmision modulator and power brakes.
Old 03-08-2010, 08:19 PM
Shag0215's Avatar
Tha Shag
dizzle
I have a factory quadrajet so where to???
Old 03-08-2010, 08:21 PM
Shag0215's Avatar
Tha Shag
sinister
yes you can tee the lines off but it will take away from the vacuum
Sinister's Avatar
Manifold vacuum port off the Quadrajet, but I would run off the intake manifold if possible.
Old 03-08-2010, 08:24 PM
Shag0215's Avatar
Tha Shag
which should i run
what should i run to the intake and what shuold i run to my carb??? The only vaccum i am running is Distributor,power Brakes,Trans mod valve and PCV
Old 03-08-2010, 08:37 PM
Sinister's Avatar
Run a fitting like this in the intake for the modulator and brakes, run the distributor off the carb, PCV to the carb. http://www.classicindustries.com/con...rchCatalogId=1
Old 03-08-2010, 09:04 PM
Shag0215's Avatar
Tha Shag
thank you
thank you sinister
Old 03-09-2010, 10:09 PM
This is the factory setup on my 1975 SBC 350.
- Intake fitting on the back of the manifold - this fitting has a short hose and then a multi-point connector, which connects to the TH350 kickdown, vacuum door on the air cleaner snorkel, and to the HVAC canister
- Power Brake booster connects to the large port on the back of the Quadrajet, using a short section of steel line with a fitting that screws into the back of the carb.
- Distributor vacuum advance connects to ported vacuum on the front of the carburetor (small port on the front)
- Rubber line to the PCV valve connects to the large port on the front of the carburetor
That arrangement is the factory setup for 1975 HD truck emissions, and its just about the bare minimum set of vacuum lines you can use. Of course, if you have a race vehicle you might get by without lines for vacuum advance, PCV valve, and HVAC.
Bruce
help with timming 84trans-am Engine 27 07-25-2009 05:13 AM
Need some clarification on Timing. Any volunteers? Midwest kid Engine 15 07-22-2009 09:45 AM
Operation of Vacuum Switch for TCC Lockup JohnTN Transmission - Rearend 1 07-11-2009 12:23 AM
How much is too much advance Mertz Engine 33 04-26-2008 12:11 PM
at wits end on ford brakes....... crazy larry Suspension - Brakes - Steering 30 04-06-2004 06:39 AM
