vacuum at idle
Hi all,
Just curious, when setting the idle mixture on my newly broken in engine, the max vacuum at ~800 rpm in PARK was about 14 in. It is a 460 bored .030, 9.5:1 with a holley avenger 770 and performer RPM intake. Does this vacuum seem appropriate...also, anyone with a dyno program to estimate hp/tq? In a couple of weeks I will probably get a chassis dyno tune and will report back here with numbers. Not so much concerned about hp numbers as I am the tune...but am still curious. Thanks The cam specs are: @ .050 lift; duration is 224 int/234 exh with gross lift .544 int/ .569 exh -rocker arm ratio 1.73 -Aluminum Cobra jet heads with 2.19/1.76 valves FYI, the Melling part no. is 24207. Their site shows this cam range should be ~2200-6000 rpm with peak torque at 3000 rpm. |
Without all exact inputs, using 110* lobe seperation, I came up with 564 FT/LBS at 3600 and 437 HP at 4300.
I'm sure the HP is way off. I can work on it a bit when I get home tonight. Do you have the exact cam specs? Interesting that vac at idle shows 15". I just checked and I had the bore x stroke wrong. |
I checked it out again.
534 FT/LBS at 4000 467 HP at 5200 14.4" vac idle |
| Low idle and vacuum questions | LOWbutnotSLOW | Engine | 1 | 05-25-2010 09:52 PM |
| No Vacuum at Idle.... | hotroddin78 | Engine | 13 | 12-15-2009 02:36 PM |
| Vacuum too low at idle? | 406 bug | Engine | 18 | 10-02-2008 03:39 PM |
| Vacuum at idle | PAS55 | Engine | 6 | 01-31-2006 11:58 AM |
| how much vacuum at idle? | Super Chevy | Engine | 10 | 05-21-2004 04:07 AM |
