Pas55-I read your post a few times and still not really sure what you are asking. If the new cam is larger with more lift and duration you may have a drop in vacuum. 13" is still good/decent vacuum. If you have power brakes and they still feel good and it runs good, then you should have no issues. It is impossible to say what the vacuum should be. There are alot of varibles that are at play. Just adjusting the carb ot timing could change the vacuum on any given cam. Hope this helped.
I'm getting 16 on my 454 with an almost identical cam. If you're using a stock ignition curve setup, don't expect more than about 13. Recurve that puppy, bump up your initial to whatever your compression allows, then you can back the idle adjustment screws way back. You'll get a smoother idle, more vacuum, and better MPG.
| Distributor Tuning and Theory - Part 1 | Rick WI | Engine | 35 | 04-26-2011 12:38 AM |
| Vacuum adv.. | underdog305 | Engine | 58 | 01-30-2007 11:19 AM |
| I'm going to make a bonfire out of my car | blown69stang | Engine | 36 | 08-22-2005 03:36 PM |
| Timing ?'s, Idle Speed and Ported vs Manifold Vacuum | JoeS | Engine | 5 | 11-03-2004 12:34 AM |
| Low Idle Vacuum on 94' TBI Suburban | edge | Engine | 4 | 07-21-2004 12:49 PM |
